Clunking and Thumping sound when hitting bumps
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOTTApro142, Feb 6, 2025.
  1. Feb 8, 2025 at 7:58 AM
    Glamisman
    Glamisman Well-Known Member
    I have seen the upper mount for the front strut assembly wear the bushings and the strut shaft saw its way into the upper strut housing. You should be able to take the upper nut up enough to slide the busing up to see if this is it.
    Parkvisitor likes this.
  2. Feb 8, 2025 at 9:32 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Another vote for it potentially being a wheel bearing. I had a front wheel bearing that would clunk on my 02 Tacoma. Had no idea wheel bearing made that noise and didn’t whine when they were bad.
    Red_03Taco and Black97v6MT like this.
  3. Feb 8, 2025 at 10:04 AM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    i priced all those parts out at the dealershop i use with the 31 off MSRP
    164$ for all new OEM
    if this fixes that cot awful clunk in my rig i will treat you to a fancy night out on the town next time i am in the so cal area
    LMAO
  4. Feb 8, 2025 at 10:06 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    with our trucks being 20+ years old this isn’t wasted $$. You’ll notice a difference
    Black97v6MT[QUOTED] likes this.
  5. Feb 8, 2025 at 10:37 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    The Energy Suspension poly bushings are fine too. The only bushings it seems like OEM is important for are the engine and transmission mounts that need to have the right resonant frequency to absorb the engine vibrations, while other bushings can be anything in good shape. But I could be wrong.
  6. Feb 8, 2025 at 11:10 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    OP does thus truck have any history of ever having had the lower control arm bushings replaced?
    Black97v6MT likes this.
  7. Feb 11, 2025 at 9:56 PM
    NOTTApro142
    NOTTApro142 [OP] Member
    Seth
    Southern California
    A 2003 Toyota Tacoma prerunner Xtracab
    Raceline Wheels, 33" tires, Camburg upper control arms with ICON 2.5-3" lift, simple overlander
    Is it possible that it could be my driveshaft? I've heard that an ungreased slip yoke can make a clunking sound when shaking around too much, lately I have been noticing a Bigger 'thud' when putting it in gear, and the common jerk when stopping and starting. I have jacked up both of my front wheels to check for bearing play and they are both tight, my sway bar bushing are pretty bad, but they aren't the cause of the noise, since the sound would happen everywhere.
  8. Feb 11, 2025 at 10:02 PM
    NOTTApro142
    Seth
    Southern California
    I do not think its that. I have aftermarket ICON coilovers in the front, so there is no strut up front. everything I have check has been tight
  9. Feb 11, 2025 at 10:03 PM
    NOTTApro142
    Seth
    Southern California
    i believe they were replaced not too long before I bought it, i pulled the wheels off to do brakes a few months ago and everything was tight, no wiggle or play in anything
  10. Feb 12, 2025 at 7:46 AM
    Red_03Taco
    Jerad
    That could be the case. Look up Timmy the Toolman's YouTube video on how to properly grease the slip yolk (the zerk doesn't really properly lubricate the splines, it needs to be pulled apart in order to properly grease it).
  11. Feb 12, 2025 at 9:15 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    That ford grease is good stuff, I recently performed the slide yoke greasing following Timmy’s video. Worked out great. No more slide yoke clunk.
    Jimmyrace, Black97v6MT and Red_03Taco like this.
  12. Feb 12, 2025 at 1:48 PM
    Red_03Taco
    Jerad
    Yup, I did the same thing, and have been very happy with the outcome.
    Jimmyrace likes this.
  13. Feb 15, 2025 at 6:33 PM
    NOTTApro142
    Seth
    Southern California
    So I went under the truck, and the carrier bearings got a decent bit of play, you'll see in the video, I also took a hammer with a rubber grip and knocked on different parts of the truck with the phone recording the inside sound, and the bumping from the carrier seems to sound the most similar, what do y'all think?https://youtube.com/shorts/BoTSstaOx_o?si=jV9LubmIjRWombaS - carrier bearing play, https://youtube.com/shorts/0BMaTNpLQSs?si=nLtczSc3AQflZko9 - knocking on carrier bearing cab sound. I think with that bearing and enough jumbling around I think it'll make the same noise
  14. Feb 15, 2025 at 7:48 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    What shocks do you have? Bilsteins have a reputation for this
  15. Feb 15, 2025 at 7:55 PM
    #35
    NOTTApro142
    Seth
    Southern California
    ICON 2.5" coilovers no remote reservoirs
  16. Feb 15, 2025 at 10:05 PM
    #36
    Sierra_Taco
    Sierra_Taco Member
    2017 Tacoma TRD
    Check your transmission mount. I've read the bolts are notorious for backing out. I recently noticed 3 of the 4 on my taco are missing.
  17. Feb 16, 2025 at 10:10 AM
    #37
    Black97v6MT
    iMA0
    tacoLand USA
    found some very good n' large pics of this very area here
    Front cross member | Tacoma World
    i have a broken welded nut for the bottom engine undercover aka 'skid plate' that i am trying to figure out how to DiY repair... and it is not aligned properly for some reason
    unfortunately it does not appear that the front cross member sub-assy is the correct part that the undercover attaches to :(
    which i think is this part... CROSSMEMBER SUB-ASSY, FRAME AUXILIARY
  18. Feb 28, 2025 at 12:59 PM
    #38
    NOTTApro142
    Seth
    Southern California
    If they were the rear wheel bearings, would there be a rattling or squeaking sound if I were to lightly tap the tires?
  19. Feb 28, 2025 at 1:17 PM
    #39
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I would suggest taking a good look at the front and rear shocks. I'd take one or both of the coilovers out and make sure the lower bushings aren't hosed. And just make sure the rear ones are still attached. I've see the upper eye come off the stud, or the stud itself break, and then the shock hits the bottom side of the bed.
  20. Feb 28, 2025 at 9:23 PM
    #40
    Red_03Taco
    Jerad
    I don't think so, no. Bad bearings typically cause vibrations, growling/howling, or clunking, but not rattling or squeaking
