Clunking in Front Driver Side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PcBuilder14, May 9, 2020.
  1. Jun 5, 2020 at 9:22 AM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Front radiator support bushings
    SR-71A likes this.
  2. Jun 5, 2020 at 9:59 AM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    My 2020 with less than 7k miles makes this noise sometimes.
  3. Jun 5, 2020 at 10:57 AM
    hectorko55
    hectorko55 Member
    Peter
    2018 Tacoma TRD Off Road
    Same freaking issue. '18OR with 32k miles. been doing it since basically new. Tried to have it addressed at the dealership a year ago, they said it was normal. Normal my a**. I have an appointment tomorrow am (Saturday) as my warranty is about to run out. Will post an update.
    BOZOJUICE likes this.
  4. Jun 5, 2020 at 12:52 PM
    EastVanTaco
    EastVanTaco Well-Known Member
    2017 super white Trd Sport DCLB
    Mine runs out end of month. Having aftermarket suspension etc. I am just taking it to a shop tmrw.
  5. Jun 6, 2020 at 3:09 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My friends Pro does it, been to the dealer a few times and they torqued the truck cab brackets to spec and he doesn't have the noise any longer. Hope this helps.
    Hattr1ck likes this.
  6. Jun 6, 2020 at 7:15 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Where does one find the "truck cab brackets"? I don't know what I am looking for lol.
  7. Jun 6, 2020 at 7:22 AM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I just tightened mine, the front ones are tricky to find, but once you do it isn’t too bad. Basically, there are 2 10mm screws at the bottom front corners and one plastic push lock on each side you need to remove to allow you to pull the inner fender/splash shield partially out of the way. Then I used a 14mm socket with 2 extensions and an elbow between them. Short extension close to the socket so you can clear some other things. By slightly moving the inner fender out of the way I was able to use the extensions and elbow to get to the bolt and tighten it to 40ish Ft-lbs, don’t remember exact number I used but found it here on TW.
  8. Jun 6, 2020 at 8:01 AM
    EastVanTaco
    Possible you could post a link? I need this info asap lol ...cannot seem to find it via search...
    Thanks
    Hattr1ck and BOZOJUICE like this.
  9. Jun 6, 2020 at 8:34 AM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
  10. Jun 8, 2020 at 12:48 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    I just got my truck regeared and the clunking has stopped. So logic would dictate something they took apart was loose and is no longer loose. So that may be a good starting point for others.
  11. Jun 8, 2020 at 1:49 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    OK, I'm 0-for-3 on this clunk with the dealer. They did replace the body mounts at the front below the radiator, and they were both torn, but it did not solve the clunk. I would really appreciate any decent pics or vid showing where this mount is. It's hot AF here - too hot to be crawling around aimlessly. Thanks.
  12. Jun 8, 2020 at 1:56 PM
    Ulfr
    Ulfr Well-Known Member
    Tampa, FL
    2019 DCSB 4x4 Manual
    I had the clunking sound, sounds like it comes from the glove box, only makes noise when I turn.
    Anyways I figured out it was my passenger seat making the noise when it is all the way back. I moved the seat up a little and the noise has yet to return.
    CusterFan likes this.
  13. Jun 8, 2020 at 3:19 PM
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    I found the clunk in the drivers side of my truck it is my lca's that are worn out, replacing with some dirt kings. It's the inner bushings.
  14. Jun 8, 2020 at 3:44 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Ive got a 2nd gen so it may be different, but I did new aftermarket radiator support bushings in my truck about a month ago. After my first weekend off road Ive got similar "clunking" noise somewhere in the front passenger side. Usually at slower speeds over large bumps or turning into a dip, like into a driveway or whatever.
    Already checked everything was torqued to spec including the LCA cam bolts. So yes, I agree with you. If the OP and I are describing the same noise, its probably in that area
  15. Jun 8, 2020 at 4:24 PM
    #35
    EastVanTaco
    So start with a 3k regear? Lol
    SandyTaco4x4 and SR-71A like this.
  16. Jun 8, 2020 at 4:45 PM
    #36
    Silverlogic
    Tyler
    No, start checking suspension components that need to be removed to install new gears... Thought that was pretty obvious.
    Edit: and the regear was $1700 parts and labor.
  17. Jun 17, 2020 at 2:45 PM
    #37
    hectorko55
    hectorko55 Member
    Peter
    Hi all,
    got what I think is a valuable update. Took it to the dealership once again - the same place where I got my truck. They did my T-case fluid change as asked, but advisor came back saying that the mechanic test drove it and there won't be anything they can do for me, as it only occurs when driving over bumps at "excessive speeds". Obviously a BS. Stood my ground and really, got in an argument with him. Told him let's hop in one of your truck on the parking lot and drive over the same bumps at the same speeds. If no sound, I'll walk away. "That doesn't work that way, it is obvious that you offroad your truck". The good ol' blame it on offroading.
    Thankfully, their head mechanic was there that day (Saturday) and we figured it out. Good solid guy, I've worked with him on some other issues before. Turns out there's two issues that typically cause this and Toyota knows about this. Last time they flew out their Japanese engineers to their dealership, they spent two days figuring out what causes this. There might be a TSB for this down the road.
    1) Don't remember the terminology, but there are two bolts I think on the lower control arm, where they attach to body, not the wheel. Apparently, initially they were supposed to be torqued to 60ft/lbs, later toyota changed it to 90 because they would loosen up and cause this sound, but at their dealership they torque it as hard as they can by hand. they're kinda hard to get to and he had a special wrench for it. This did not solve my issue.
    2) <blockquote class="imgur-embed-pub" lang="en" data-id="a/4AaLbd9"><a href="//imgur.com/a/4AaLbd9"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
    <blockquote class="imgur-embed-pub" lang="en" data-id="a/Kf7uwOg"><a href="//imgur.com/a/Kf7uwOg"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
    Hope this helps some of you.
  18. Jun 17, 2020 at 4:04 PM
    #38
    EastVanTaco
    So you still have the problem?
  19. Jun 17, 2020 at 4:14 PM
    #39
    .jake
    .jake Ex-Lion Tamer
    Yeah when I was reading his first bullet point I was already concluding he was on to the fix... riiight up until I read "This did not solve my issue". WTF? The links are broken too! :smack:
    SR-71A likes this.
  20. Jun 17, 2020 at 4:51 PM
    #40
    hectorko5
    hectorko5 New Member
    I tried to edit my post, but somehow got locked out and can't post. Tried reaching out to a moderator but no response yet. Had to create a new account, didn't mean to leave you hanging. Sorry for the confusion
    Here's the picture of my warranty work write up I tried posting in the previous post. This took care of the issue!
    imgur.com/a/1jguf3X
    imgur.com/a/Kf7uwOg
