clunking like something fell off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08pretaco, Aug 25, 2009.
  1. Aug 25, 2009 at 4:58 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ok so i pulled into my driveway wheel turning about a turn and a half then over the rounded curb i drive and all of a sudden....clunk clunk it goes and i felt it shake the car also. it comes from the front right wheel area.
    any ideas as to what it is? it also happens when i go in reverse backing out of the driveway :(
  2. Aug 25, 2009 at 5:13 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Steering tie rods?
  3. Aug 25, 2009 at 5:38 PM
    08pretaco
    Oliver
    az
    checked those after looking around on the forum and they are tight
  4. Aug 25, 2009 at 5:54 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    mud gaurd... been there done that
  5. Aug 25, 2009 at 6:29 PM
    08pretaco
    Oliver
    az
    mud guard?? explain please
  6. Aug 25, 2009 at 6:37 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I think he means the mud flap could be loose/broken and rubbing. Check around your axel for anything wrapped up in it, visually inspect around your wheels and brakes for anything that shouldn't be there, ect. Aside from that, I'd start looking at suspension components...
  7. Aug 25, 2009 at 7:02 PM
    08pretaco
    Oliver
    az
    dont have mud flaps and i just took it to the dealer because there was another clanking that one was fixed and this one started idk anymore. ill just see whats there and see if theres anything loose
  8. Aug 26, 2009 at 8:40 AM
    08pretaco
    Oliver
    az
    thats seems like an aweful lot of slop. looked at the whole steering as chris 4x4 posted pics in another thread and it all seems tight. im taking it to see a great mechanic near me and see what he says wont cost me anything so we will see
  9. Aug 26, 2009 at 11:52 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    check for a loose cam-bolt on the Lower control arm, the arm is slapping back and forth when your momentum changes or you hit a bump
  10. Aug 26, 2009 at 11:56 AM
    08pretaco
    Oliver
    az
    is that one of the two bolts there that is used for alignment?
  11. Aug 26, 2009 at 11:59 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    yes, looks like this.
  12. Aug 26, 2009 at 12:02 PM
    08pretaco
    Oliver
    az
    if those are loose tacoma techs suck cause i got it aligned by them and they must not have tightened them or something...could that be why my truck doest go straight when im on the freeway?
  13. Aug 26, 2009 at 12:48 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes, that could be why. Something is definitely wrong. It is beginning to sound like the tech went to lunch in the middle of the alignment.
