Clunking noise after King suspension install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SweatyBiscuit, Mar 4, 2019.
  1. Mar 4, 2019 at 3:34 PM
    SweatyBiscuit
    SweatyBiscuit [OP] Well-Known Member
    Paul
    Northern AZ
    2016 Taco TRD OR
    Katzkin leather, heated seats, Popnloc, bed lights, remote start, bhlm....
    I thought I’d share my experience with my King suspension install.
    I had a clunk in the right front after the install. I spent the extra time to re-torque everything but I couldn’t figure out where it was coming from. It drove nice and I felt safe driving it so I drove it and figured at some point I would track it down. I spent a lot of time searching threads and over the couple of weeks following the install I checked the radiator core support, front cab body mounts, removed the sway bar, double checked all the cross members, front differential mounts, front drive line, etc. All without any luck. I finally took it to a shop where they were able to trace it down to the front coil over not getting charged with nitrogen from the factory (I had heard of this happening in a random thread but I never thought it would be the case with mine. After a couple hundred in diagnosing and a nitro charge I’m good.
    Super happy with the suspension and lift now. If you have a clunk I’d recommend checking the pressure in your reservoirs before digging too deep.
    That said I was out $200 and tons of time so I called Wheelers Off-road to see if they would help. After a few weeks (they would never call me back, I always had to call them) they told me they would reimburse $20 for the nitrogen. King would not take any responsibility saying the shock likely sat in Wheeler’s warehouse too long and wheelers wouldn’t help at all. I’m torn over the experience with King because I think they make good stuff. As a consumer I was definitely caught in the middle. I would not recommend Wheeler’s Off-road at all. They basically called me an idiot and told me I should have found the problem much sooner and with less effort.
    All in all I would do it again just wouldn’t go through wheeler’s. Check your nitrogen pressure if your having issues.
    Rant over.....
    Cheers!!!
  2. Mar 4, 2019 at 5:32 PM
    Fleabitten
    Fleabitten New Member
    Orange County, CA
    2018 TRD Offroad 4x4 Double Cab Midnight Black
    When did the clunking sound occur? Was it driving at a slow rate of speed on flat surfaces or over speeds bumps? I'm curious because I experience a slight clunking noise driving slowly over speed bumps - King Suspension
    hirod likes this.
  3. Mar 4, 2019 at 5:35 PM
    SweatyBiscuit
    Paul
    Northern AZ
    2016 Taco TRD OR
    It was on smaller chattery type stuff. I would just check the pressure you need a lossless gauge that goes to 200ish psi. They should have 150 psi when suspension is unweighted.
    hirod likes this.
  4. Mar 4, 2019 at 5:38 PM
    Fleabitten
    Orange County, CA
    Thank you for your reply. I'll have the pressure checked.
  5. Mar 4, 2019 at 5:39 PM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Just ordered my King setup from Wheelers last week. So far, they've taken a lot of extra time to answer questions, which was cool. In other words, so far, so good.
    Thanks for the tip about the Nitrogen, though! It's great info for anyone who might experience the same problem, including me.
  6. Jun 17, 2019 at 7:32 PM
    dkhorse74
    dkhorse74 Well-Known Member
    Where you want to be
    Glad I found this post!! I've had this clunk noise since I had the Kings installed in Sept. of 2016. I was told it was "normal" and dealt with it.. I never felt any abnormal driving experience so I just went with what I was told. I'm going to have to figure out how to get the shocks check for nitro level..
    hirod and paleh0rse like this.
  7. Jul 11, 2019 at 10:48 PM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    subbed. thought i had a clunk before with my icons but not sure. definitely have a low speed bumpy road tapping now w kings. checked everything except lca bushings and shock pressure.
  8. Jul 11, 2019 at 11:05 PM
    mhshark
    mhshark Well-Known Member
    Bend, Or
    I bought an OME setup from Wheelers and they were super quick to respond and overall great to deal with. After my coils started sagging a ton (only getting 1” out of 886 coils) I contacted them explaining that I thought they were faulty and it was like pulling teeth to get a response. I actually think the last email I sent to them was not responded and it was a follow up. Definitely great service before the order is placed but once you have your stuff you seem to be on your own.
  9. Jul 12, 2019 at 5:43 PM
    PeterMN
    PeterMN Well-Known Member
    Fort Bragg, NC
    2018 ORD DCSB Cement
    Sucks that this happened to you, I hope companies like king, total chaos, etc.. will allow us to order direct in the future to mitigate this from happening to more people.
