Clunking noise in front suspension..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solution.45, Apr 14, 2018.
  1. Apr 17, 2018 at 3:16 PM
    #61
    Solution.45
    Solution.45 [OP] Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    Oh okay I see
  2. Jan 16, 2019 at 8:41 PM
    #62
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    Did you ever figure out issue? Have an '06 with similar clunking noise coming from front. Toyota just quoted me $1,300 to replace UCA saying that was culprit... was wondering what your solution was?
  3. Jan 16, 2019 at 10:48 PM
    #63
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    $1,300 to replace UCAs??? Are they putting in Total Chaos heim joint UCAs?
    That's insanity pricing right there for stock UCAs.....
    Kolter45 and wilcam47 like this.
  4. Jan 17, 2019 at 1:41 PM
    #64
    glockner
    Scottsdale, AZ
    SPC... $560 for parts and rest of the math for labor! Quoted 5 hours of labor for whole job....
    20somethingwidataco likes this.
  5. Jan 17, 2019 at 5:10 PM
    #65
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I pulles the sway bar off, sound went away for a few days but it came back. I put some cardboard wrapped in duck tape between my bumper and fender to prevent any chance of them coming into contact and the sound went away again. I am going to have to re adjust my front bumper but will have to do it in a few months because im being deployed for alittle.
  6. Jan 17, 2019 at 5:12 PM
    #66
    Tanselow
    Tanselow Well-Known Member
    22 trd or
    Sounds like the front skid plate bouncing around
  7. Jan 17, 2019 at 5:13 PM
    #67
    757yotas
    Virginia
    2007 TRD Sport
    Skid is very snug lol ive checked and re checked that
  8. Jan 17, 2019 at 5:27 PM
    #68
    Jollydropdraws
    Jollydropdraws Active Member
    I had a similar problem with a new OME lift. Was getting a clunk when I went over speed bumps (on the downside of the bump, ie the rebound stroke. Turns out ARB sent the wrong springs. They were too stiff for the struts.
    Maybe something to consider?
  9. Jan 17, 2019 at 5:29 PM
    #69
    757yotas
    Virginia
    2007 TRD Sport
    Hmm...i have 887 coils on 5100s bottom setting. I wonder if that could cause some strange issue??
  10. Jan 17, 2019 at 6:07 PM
    #70
    Jollydropdraws
    I had the stiffer 887 coils instead of 885's.
  11. Jan 17, 2019 at 8:56 PM
    #71
    Taco2525
    Taco2525 Well-Known Member
    Los Angeles
    2009 access cab trd-offroad 4x4
    Lol once the tires are off that’s maby 30 minute job each side I would look into doing it yourself it’s pretty easy
    SandyTaco4x4 likes this.
  12. Jan 17, 2019 at 8:56 PM
    #72
    Taco2525
    Los Angeles
    Almost a thousand dollars in labor to install upper control arms there has to be a mistake on there end as far as the quote goes
  13. Mar 24, 2019 at 5:21 PM
    #73
    Gat_
    Gat_ Don’t be shattered.
    Bay Area, CA
    '19 Cement Tacoma TRD OR M/T
    @Solution.45 hey did you ever figure out your issue? I got something similar after lifting the truck with BP-51s.
  14. Mar 24, 2019 at 5:43 PM
    #74
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Depending on how much extra weight you have up front and what preload you have it set at they may be topping out. I had mine set at the 20mm preload for winch and steel bumper and they still topped out even though I have a winch, bumper, full skids, sliders, dual battery in the engine bay.
    I dropped the preload down to 15mm this weekend and I'll see if it still tops out.
  15. Mar 24, 2019 at 7:37 PM
    #75
    Gat_
    Bay Area, CA
    I believe mine were OMEs newer batch as they were shipped with 10mm of preload.
    It’s like a strange rattling sound that is hard to replicate. It happens when I’m coasting 20-30mph or when I’m coming to a complete stop.
    Lilhooter82 likes this.
  16. Mar 24, 2019 at 9:53 PM
    #76
    Taco2525
    Los Angeles
    Did you have your alignment done after the install? I’d hope so if that’s the case check the Torque on your lower cam bolts
  17. Mar 24, 2019 at 10:26 PM
    #77
    wyotacotrd
    wyotacotrd Well-Known Member
    Cade
    Laradise, Wy
    White 2012 DCSB TRD Offroad v6
    Fox 2.5 Remote Resevoir Coilovers, SCS Ray10 bronze, IVD progressive AAL, Fox 2.0 Remote Resevoir rears, Wheelers OR bump stops, Prinsu design studio cabrac, Softtop in Tan, etc...
    I can tell you from my experience, of having both fox and king coilovers, stock and uniball upper control arms, that the noise is just the coilover toppling out and maxing out it's down travel. I have 650# coils on my kings right now, with enough preload on them that any bump that requires more that 2 inches of down travel, I get a clunk. Your option is to adjust the coilover to much less preload, and you will have more down travel, or just roll with it and know that nothing bad is happening. It's annoying, but not the end of the world.
    kevron likes this.
  18. Mar 25, 2019 at 9:43 AM
    #78
    Gat_
    Bay Area, CA
    Yeah got an alignment after I installed the kit. Even the mechanic said he heard the sound on a test drive but couldn’t pinpoint what it was.
    I hope that it isn’t anything major. I’ve rechecked all bolts abd everything seems fine. I might try adjusting the compression and dampening and see if that helps.
  19. Apr 5, 2021 at 10:16 AM
    #79
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    There are spacers.....?
  20. Oct 14, 2022 at 4:56 PM
    #80
    Buzzkill657
    Buzzkill657 Well-Known Member
    Jeff
    lol what?
