Clunking noise in front suspension..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solution.45, Apr 14, 2018.
  1. Oct 14, 2022 at 5:00 PM
    #81
    Dagralph
    Dagralph Well-Known Member
    2015 SW DCLB taco
    so this is where I posted that message... :anonymous:
  2. Oct 14, 2022 at 5:01 PM
    #82
    Buzzkill657
    Buzzkill657 Well-Known Member
    Jeff
    this post is even more funny
  3. Aug 13, 2024 at 10:10 AM
    #83
    KBraden79
    KBraden79 Active Member
    2012 trd sport Tacoma
    So has anyone had the problem of it clunking or popping when you back up and turn the wheel? Like something is getting in a bind and breaking free. Started happening a few years ago after I put 3.5 lift struts from rough country JBA upper control arms TRQ lowers and an alignment. Been this way for years now since I have put different cv (about to buy cvj remans) and wheel bearings in it and it’s still doing it. Also I do have a 1”diff drop kit install thinking the angle of the cv was the problem. Any help would be appreciated thanks!
  4. Aug 13, 2024 at 10:16 AM
    #84
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Sounds like it could ne the CVs binding.Does it mostly do it on sharp turns, like turns where the steering wheel is maxed out?
    KBraden79[QUOTED] likes this.
  5. Aug 13, 2024 at 10:22 AM
    #85
    KBraden79
    Almost maxed but it also does it if I slow turn and turn going forward along with if I brake a little to hard. I have no idea what brand of cv I have rn and the boot ripped yesterday that’s why I was going to buy CVJ axles. But I was thinking the sound could be the LCA bolts or bushings.(the shop I went to has swapped these axles out at least 4 times and it’s the same sound everytime)
  6. Aug 13, 2024 at 10:25 AM
    #86
    Buzzkill657
    Jeff
    Are you sure that’s not just the brake slap. Mine does it all the time when applying.
    As to your original problem did you replace the needle bearings that everyone talks about with a lift. I’m stock so I still have mine
  7. Aug 13, 2024 at 10:30 AM
    #87
    KBraden79
    I have not replaced the needle bearing I don’t believe. And are you talking about the brake stop that’s on the caliper? If so it does it before I even make it that far.
  8. Aug 13, 2024 at 10:32 AM
    #88
    Buzzkill657
    Jeff
    everytime I brake I hear a small clanking sound from the pass moving in the caliper
  9. Aug 13, 2024 at 10:38 AM
    #89
    KBraden79
    I would say it’s the brake of it was only doing it when I was braking but it’s more then just hitting the brakes.
  10. Aug 13, 2024 at 10:51 AM
    #90
    Buzzkill657
    Jeff
  11. Aug 13, 2024 at 11:48 AM
    #91
    KBraden79
    It does happen when I hit the brakes but not everytime. And yes that helps thank you!
  12. Mar 29, 2025 at 4:42 AM
    #92
    alkarca
    alkarca Member
    2009 Tacoma SR5
    Have you solved it?
    I have similar issue, please refer to my first post with the videos
    https://www.tacomaworld.com/threads/clicking-sound-front-end-video.855444/#post-30534329
