Clunking noise question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ensemaine, May 18, 2020.
  1. May 18, 2020 at 10:18 AM
    ensemaine
    ensemaine [OP] Active Member
    Davis, CA
    Hey all. I've been hearing a clunking noise from around my front end. Sometimes when I'm reversing and turning and I brake and come to a complete stop, I hear a clunk. It happens mostly under this situation but I'm sure there's other times where it may clunk.
    Is this with my brakes or is there play in my front suspension?
  2. May 18, 2020 at 10:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check your cv boots for rips. Check your front drive shaft for a bad u-joint. Check your ball joints.
    b_r_o likes this.
  3. May 18, 2020 at 10:44 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the alignment bolts at the lower control arms. They need to be torqued to 100 lb/ft
    98tacoma27 likes this.
  4. May 18, 2020 at 10:49 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    If it only happens when you apply the brakes, I would check the brake caliper bolts. I had that issue after I replaced my calipers.
  5. May 19, 2020 at 1:13 PM
    ElChapoSr
    ElChapoSr Well-Known Member
    Al
    Be sure to check you tie rods, both inner and outer. I chased a front end clunk for a long time that ended up being an inner tie rod. Could only feel it at low speeds, when turned, with slight front end articulation.
    Nevin likes this.
  6. May 19, 2020 at 9:45 PM
    Glamisman
    Glamisman Well-Known Member
    in addition to the above, check where the shock goes through the upper spring retainer. I the mounts were not replaced the shock shaft can wear slot in the upper mount and be banging around.
  7. May 19, 2020 at 10:38 PM
    pontoon
    pontoon Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Is it a single clunk or multiple clunks? Mine clunks sometimes when I brake. Sometimes it clunks/shudders multiple times really rapidly. It’s a really strong clunk, kind of feels like I got hit from behind. Been unsolved for a year now. Lmk if you solve yours.
  8. May 20, 2020 at 4:45 AM
    ElChapoSr
    Al
    Nevin likes this.
  9. May 20, 2020 at 4:32 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Lots of good suggestions here. Here's another:
    I too had a light clunk. It occurred when I made a left turn from a dead stop. Not all of the time though.
    So I took it to a Toyota shop (not a dealer) and after paying $1,300 for a replacement steering rack, lower ball joints, and an outer tie rod, the clunk was still there and I immediately took it back. The mechanic sprayed some lube on the sway bar mounting bushings and the clunk went away, never to return.
    You might want to check your sway bar mount bushings. Put some grease on them and see if the clunk disappears.
    jammer and GQ7227 like this.
  10. May 22, 2020 at 7:42 AM
    skeezix
    Colorado
    1998 Limited
    I had the steering rack replaced when the truck had 58,000 miles on it. It now has 101,000 miles on the clock.
    It all depends upon where you drive the truck. Over the last 28 years I've driven just about every remote dirt road in southeast Utah, central west Utah, and central east Nevada and I'm hear to tell ya that some of the roads pretty damned rough. On most of roads I couldn't drive any faster than around 10 mph.
    The ruts and potholes have certainly taken their toll. The replacement rack now has 43,000 miles on it and it needs to be replaced again. :( Looks like I was taken to the cleaners when I had the rack replaced the first time. I just don't trust mechanics with my truck anymore, and I'm getting too old to do a lot of the work myself.
    GQ7227 likes this.
  11. May 22, 2020 at 7:54 AM
    ElChapoSr
    Al
    ^This is important. I drive mainly on washboard roads, often around 20 mph, which will beat the heck out of any vehicle.
    What makes you think you need to replace the steering rack @skeezix? That just sounds premature, but if you drive it off road a good deal...
    GQ7227 likes this.
  12. May 22, 2020 at 8:52 AM
    Glamisman
    ditto on the getting too old. Now, I will work on the project until I can feel my back/neck muscles tightening and then stop for an hour, then go back to it later on. I tell my "customers", usually family and friends that don't trust mechanics for good reasons, that these are the rules, I will get to it when I can and I will either repair it or replace it and if you are in either a hurry or feel that it is going to be too expensive, take it somewhere else.
    When I was spinning wrenches at the Porsche/Ferrari dealer it was like this... leave an estimate for $1k and I will call you when it is either done or I need more $. I would leave the car on the rack and the service writer would bring the customer back and i would explain what I did, why I did it and answer every question until they were satisfied. When you have a line of cars waiting for you and only you to work on their cars most mornings, well, the proof is in the service drive. Other techs flagged more hours but my tickets generated the most $ and satisfied customers.
  13. May 23, 2020 at 7:57 AM
    skeezix
    Colorado
    1998 Limited
    I suspect something in the rack is worn out. When I rock the steering wheel back a forth just a little bit, the shaft that is connected to the lower end of the steering column moves but the tie rods do not. If I rock the steering wheel a little farther, then the tie rods move, and then I hear a clunk that's coming from the rack.
  14. May 23, 2020 at 1:02 PM
    ElChapoSr
    Al
    That's what steering rack 2 and 3 had for me, I'm convinced the roller style guide on the aftermarket racks had some play, and eventually caused my inner tie rods to get play in them.
  15. May 24, 2020 at 10:18 AM
    skeezix
    Colorado
    1998 Limited
    Could be, but the rack that's currently installed in my truck does not have the roller inside, just the bushing "puck".
    ElChapoSr likes this.
