Clunking noise when reversing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Egghead, Mar 30, 2025.
  1. Mar 30, 2025 at 2:29 PM
    Taco Egghead
    Taco Egghead [OP] Well-Known Member
    I've noticed this previously as well that when I reverse and lightly tap the breaks I hear a clunking noise . Same when I'm going forward. What does this mean?
  2. Mar 30, 2025 at 2:31 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It’s the brake pads shifting in the caliper. Nothing concerning.
  3. Mar 30, 2025 at 2:48 PM
    Taco Egghead
    Gotcha. I do need to change my front pads too so that may be part of my concern.
  4. Mar 31, 2025 at 3:22 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The brake grease gets gummed up from road debris. You need to pull pads, clean backside of pads and shims. Clean pad pins, re lube back of pads, shims and pins. Re install and you should be good. I do mine once a year.
    Taco Egghead[OP] likes this.
