Clunking noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jedrovsky, Jul 30, 2011.
  1. Jul 30, 2011 at 11:48 PM
    jedrovsky
    jedrovsky [OP] say NO to BRO!
    San Diego, CA
    07 PreRunner
    DIY stuff
    OK, I have a 07 DC prerunner..it has 56xxx miles and whenever I back up and turn I would hear a clunking noise and sometimes as I drive away coming from the front of my truck. What are your guys' opinion to what is making that "clunking" noise...I was thinking that its probably from the steering rack or brakes? I searched here but most are from 1st gen. tacos'
  2. Jul 30, 2011 at 11:50 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Only once when you first start driving? ABS self test....sounds like a spring being sprung? Normal.
    If its actually a clank, could be your brake pads, which is also normal
  3. Jul 30, 2011 at 11:54 PM
    jedrovsky
    San Diego, CA
    07 PreRunner
    DIY stuff
    everytime I back up and turn and sometimes when I drive away..It usually happens when the wheel is fully turned both ways..ABS self test?..how do you do that?..(noob question)
  4. Jul 30, 2011 at 11:58 PM
    brian
    Elizabeth City, NC
    You don't control the ABS test, but it does it when you first start driving. I don't remember if it only does it in reverse or not.
    Does it sound like a spring being sprung or more like a clank of metal?
  5. Jul 31, 2011 at 12:01 AM
    jedrovsky
    San Diego, CA
    07 PreRunner
    DIY stuff
    more of a clank...its pretty loud too
  6. Jul 31, 2011 at 12:07 AM
    brian
    Elizabeth City, NC
    K, does it happen when you first press the brake pedal? If so, its the brakes adjusting. You could be coming due for a new set of brake pads. Its still normal though.
    If it is always happening and not just when you first start driving then Id suspect bad bushings or ball joints, but your mileage is still pretty low, so Id be surprised.
  7. Jul 31, 2011 at 12:10 AM
    jedrovsky
    San Diego, CA
    07 PreRunner
    DIY stuff
    before and after i press on the brake...what mileage are the bushing usually worn?
  8. Jul 31, 2011 at 12:12 AM
    brian
    Elizabeth City, NC
    Couldn't tell ya, with normal highway driving it could be awhile. I'm at 90k miles on mine and they're still in good condition. Much better than any domestic I've ever driven.
    If you could take a video with your phone and post the sound its making, it would help...otherwise I can't do much better given your description. There are also plenty of TW members in your area that might be able to help you.
    If you can tell me exactly what triggers the noise, then I could figure it out. Ie, stepping on the brake can make a noise, turning the steering wheel can make another noise. Putting it in drive can be another noise.
    If its in the steering rack, then you should be able to hear the noise by cranking the wheel back and forth, and would not require the vehicle to be moving.
    If its brakes, you should be able to reproduce without turning.
  9. Jul 31, 2011 at 12:21 AM
    jedrovsky
    San Diego, CA
    07 PreRunner
    DIY stuff
    Will do.. Thanks for the help though I actually know someone who can help me out....Just wanted an opinion from TW members about it
  10. Jul 31, 2011 at 12:21 AM
    brian
    Elizabeth City, NC
    If however, you can only reproduce the noise while driving AND turning, then Id guess ball joints.
  11. Jul 31, 2011 at 12:22 AM
    brian
    Elizabeth City, NC
    I'm sure others will chime in, I'm guessing I'm the only one that's up this late right now though.
  12. Jul 31, 2011 at 12:24 AM
    jedrovsky
    San Diego, CA
    07 PreRunner
    DIY stuff
    usually when I back up and turn at the same time and the initial drive away
  13. Jul 31, 2011 at 12:25 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    If the brake pad clips are not put in right, they will move farther than usual and cause a clunk. Especially after going from reverse to drive. You will also notice it going over things like speed bumps...
    If that's the case, put them on correctly so they don't have a lot of play and it will be reduced greatly.
  14. Jul 31, 2011 at 12:27 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    Also, if you are turning your wheel all the way to lock, the steering stops will rub causing a poping noise.
  15. Jul 31, 2011 at 12:28 AM
    jedrovsky
    San Diego, CA
    07 PreRunner
    DIY stuff
    yea...i figured it would have been either the brakes or steering rack..because the steering wheel shakes at 65mph and above
  16. Jul 31, 2011 at 12:29 AM
    brian
    Elizabeth City, NC
    Yeah, I'm thinking along the line of ball joints then. You might be able to feel them if you grab your tire and try yanking it towards you forcefully. If you do it strong enough it should shake your truck and you will hear and feel the same noise. You can also visually inspect them. They are the two large joints, upper and lower that hold your axle hub on. Look for broken boots and grease coming out.
  17. Jul 31, 2011 at 12:31 AM
    brian
    Elizabeth City, NC
    Steering wheel shaking can also be a sign of bad ball joints. Had exact same symptoms on one of my old cars when it went out. Unfortunately, the way our tires/wheels are balanced... (Hub-centric) it could also just mean your tires out of balance.
  18. Jul 31, 2011 at 12:41 AM
    jedrovsky
    San Diego, CA
    07 PreRunner
    DIY stuff
    well..i know what im doing tomorrow..hopefully this aint too bad
  19. Jul 31, 2011 at 5:18 AM
    Tacoma Joe
    Tacoma Joe Member
    Joe
    Maryland
    09 Prerunner
    Total Chaos
