clunking noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by John82352, Jun 23, 2016.
  1. Jul 14, 2016 at 9:17 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Did these parts eliminate the axle clunking noise?
  2. Jul 14, 2016 at 10:10 AM
    John82352
    John82352 [OP] Member
    2001 Toyota Tacoma
    No actually I added the leaf spring helpers which stopped the wrapping of springs, added new center carrier bearing and replaced the transmission support. All the above has no effect on clunking. almost has like a ringing to it after initial sound.
    PROseur likes this.
  3. Aug 16, 2016 at 11:10 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The clunk is from the drive line and the axle wrap from live leaf suspensions may add or detract to it, but the root cause is the drive line. This also happens in coil sprung suspensions.
    I explained quite a bit here, long read but I tried to break it down so people could visualize what's going on within the driveline. I hope it helps:
    https://www.tacomaworld.com/threads...rk-doesnt-accept-grease.443555/#post-12925641
