Clunking Sound Hitting a Dip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mbcnya, Mar 14, 2018.
  1. Mar 14, 2018 at 12:45 PM
    mbcnya
    mbcnya [OP] Well-Known Member
    San Diego, CA
    TRD Sport Package TRD Pro Grill Front Window Tint 35% Rear Window Tint 20% OEM Kicker Tweeters Kicker Front 6x9 3-Way Speakers and Kicker Rear 6.5" 2-Way Speakers Bilstein 5100 Front and Rear Shocks with 1.1” lift and with 1/4" ORW Spacer on Drivers Side Pro Comp Rockwell Series 34 Wheels with Black Lug Nuts Tacoma Lower Black Valance Predator Tube Steps Falken Wildpeak A/T3W 265/70/17 at 6,000 Miles TRD Shift Knob OVTune 1.03 Valve Stems Black Aluminum TRD Cat Back Exhaust DCSB Plastidip Badges Black Toyota Tacoma OEM All-Weather Floor Mats DDM Tuning HID Low Beam Kit 5500K Supernova V.3 LED High Beams TRD Pro Hood Bulge with Plastidip Scoop Plastidip Fender Flares Black MESO Ultimate LED Mirror Signals Rugged Premium Hard Fold Tonneau Cover Blacked Out Headlights Mod Toyota Bed Extender Diode Dynamics Reading and Dome Light LED’s Tailgate Pop n Lock MESO Gasshole Morimoto XD LED Fog Lights LED Bed Lights OEM Mud Flaps
    Just got my truck 10k mile serviced, Tire Rotated and Balanced, running Bilstein 5100's with stock springs set at 1.1" lift, noticed the other day whenever I hit a dip I hear a loud clank like metal on metal around the front middle and right side. I don't feel it in the steering wheel or seat, just the sound. There are no leaks and everything "looks" solid. Driving is smooth, bumps are fine, its only long deep dips at a moderate speed the clank happens. I don't think any of my stock suspension is bad, only 10k miles on it. I don't want to take it to back to Toyota and sit for 3 hours, thought I'd check here first. Any ideas on what it may be?
  2. Mar 14, 2018 at 12:46 PM
    Ossaris
    Ossaris A Bad Person Doing Good Things
    Aliens
    SoCal
    2016 TRD OR 4x4 w/ 6112s & 5160s
    Lights for days! Sasquachified!
    Possibly your tires quickly bumping into plastics or whatnot in the wheelwells?
  3. Mar 14, 2018 at 12:49 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    check to see if your skidplate bolts are loose. I get a clunk every now and again.
    Just discovered today that the oil change techs (that usually are awesome) forgot to put the bottom 2 bolts in based on a clunk&rattle
    su.b.rat likes this.
  4. Mar 14, 2018 at 12:49 PM
    coopnugz
    coopnugz Well-Known Member
    Cooper
    2022 Black Trail
    From my thread lurking I've seen a lot of people mention a similar noise being caused by their LCAs - maybe check that nothing is loose down there, no play in anything, etc.
    For what it's worth, I had the exact same noise coming from my 1st gen any time I'd go over dips and upon swapping out my old struts I've never heard the noise ever since...
  5. Mar 14, 2018 at 1:03 PM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    Ball joint boots all good? Although I feel like it would be more frequent.
  6. Mar 14, 2018 at 1:05 PM
    mbcnya
    San Diego, CA
    Ball joints are still good. I removed my skid plate to look behind and it still clunked, I'll probably look again since its been a week. I haven't checked the LCA's, ill do that tonight. I hope its not my struts! Those are still new :(
  7. Mar 14, 2018 at 1:06 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Go through everything with a torque wrench and make sure everythings to spec, lot of times work gets done and some one (not pointing any fingers) forgot to torque something. This can lead to rattles and clanks or worse. Just my 2 cents.
    ponts likes this.
  8. Mar 14, 2018 at 1:07 PM
    mbcnya
    San Diego, CA
    Ahh, I never thought about going over it with a torque wrench. I just did a hand test to make sure nothing was loose.
  9. Mar 14, 2018 at 1:07 PM
    strktly_bodysurf
    +1
    impact gun isn't tightening something to spec. Plenty guys are lazy and just want to get your truck in and out as fast as they can
    2016Tacoman and Slashaar[QUOTED] like this.
  10. Mar 14, 2018 at 3:44 PM
    Dank24
    Dank24 Well-Known Member
    3rd gen OF
    I also hear this noise recently, I’m taking it to the dealer Friday
  11. Mar 14, 2018 at 4:13 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Check the cab mounts... look at your truck from behind on level surface - see if you have a lean... driver lean usually normal. Look for the bed to be slightly mis-aligned..
    Some have had cab mounts cracked and beds not aligned causing the clunk... then there's that forgot to tighten skid plate thing.... I didn't know they had to touch the skid plate to change oil. My sock skid was pretty small.. now much better.
  12. Mar 14, 2018 at 8:46 PM
    mbcnya
    San Diego, CA
    Let me know what they find!
    I did go off-road recently, dumb question, but where exactly are the cab mounts? I installed a 1/4" spacer on the drivers side when I installed my shocks.
    bobrown14[QUOTED] likes this.
  13. Mar 15, 2018 at 4:40 AM
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
    Try lightly hold your brakes through the dip. I have a similar sound and the shop foreman I rode with suspected the calipers had some play and rattle. Low and behold when I gave light brake pressure the sound did not occur
    mbcnya[OP] likes this.
  14. Mar 15, 2018 at 9:53 AM
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Same issue here. Dealer replaced multiple body mounts. "checked and re torqued" everything in the front end.
    Sound comes from the front. Yet with chassis ears they say its the rear. Next up, Replacing rear springs and all bushing associated....
    I have a case open with toyota on this as I've been dealing with it for well over a year and have been to the dealer countless times. Currently waiting on parts to show up and then ill report back after they replace the rear leafs... Which I know isn't going to do anything. But I'll take the new leafs and bushings.
  15. Mar 15, 2018 at 10:01 AM
    Fortunt1
    Fortunt1 Well-Known Member
    Thomas
    Iowa
    16' SRT Charger...purple
    Sub’d Cause I have the same lol
  16. Mar 15, 2018 at 10:28 AM
    mbcnya
    San Diego, CA
    Ill try that today! It's weird, I'll drive over the same dip and hear it, then come back the same way and won't.
    Oof! Has it happened from the beginning or just randomly one day?
  17. Mar 15, 2018 at 7:27 PM
    Dontporget
    Dontporget Member
    Billy
    Super White 2018 TRD Sport
    Driver Mod.
    I have the same issue! I have the manual though. I think sound does not occur when I'm in gear.... Still have to test this theory more.
    Was planning to wait until my 5k service interval!
  18. Mar 15, 2018 at 7:37 PM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    i think mine was the trans crossmember. removed all my skids. tightened my body mounts (poly) and checked my ball joints and uca and lca bushings. even checked the exhaust. tightened up the crossmember last and sound hasn't been heard since.
  19. Mar 15, 2018 at 7:47 PM
    felkebg
    felkebg Well-Known Member
    Bill
    Auburn AL
    2017 Tacoma
    My trailer ball makes a clunk every time it hits the pavement leaving my driveway..... it has a five inch drop on it.
  20. Mar 22, 2018 at 5:38 PM
    mbcnya
    San Diego, CA
    torqued all my lugs to spec and everything in between. I'm starting to believe its the little give the brake calipers have that @barcelona7568 mentioned. I give it a slight brake and no sound.
