Clunking sound while turning in 4wd hi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD4x4offroad, Nov 25, 2015.
  1. Nov 25, 2015 at 10:50 PM
    TRD4x4offroad
    TRD4x4offroad [OP] Active Member
    Calgary, AB
    2015 Tacoma TRD Offroad V6 4x4
    There was a dump of snow yesterday and it was the first time I used the 4wd extensively on the way to work. I noticed a couple of times when turning there was a very noticeable clunking or thumping sound. It disappeared immediately once I straightened out. This was during normal left turns on the street, nothing tight radius like a parking lot. The roads were mostly snow covered and slippery so I would assume there was enough slippage to avoid drivetrain binding? Or maybe I should give the rugged trails some credit for relatively decent grip. The truck wasn't too bad in 2wd either, I used it on the freeways and switched to 4wd in the neighborhoods with unplowed streets. The traction control kicked in a few times in 2wd and you could feel it cutting power to the engine and the light blinking on the dash. So what's making these noises in 4wd, normal or not?
  2. Nov 26, 2015 at 5:25 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Given your description it's the 4wd binding while turning. Even in slippery conditions the 4wd can have some slight binding.
    And no, give no credit to the rugged fails. Terrible tires.
    TRD4x4offroad[OP] likes this.
  3. Nov 26, 2015 at 5:39 AM
    2000TRDTaco
    2000TRDTaco Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    Some binding and noise while using 4wd is normal
  4. Nov 26, 2015 at 5:43 PM
    TRD4x4offroad
    Calgary, AB
    OK good to know it's normal, not accustomed to these strange noises. :rolleyes: A co worker with a new GMC Sierra SLE mentioned having a feature called autotrac and boasted about it. Apparently he just switches the selector knob to auto and the 4x4 works like awd and there's no need to worry about binding. Not sure how that functions, I thought the GM full size trucks were part time 4wd systems like ours without a centre diff.
  5. Nov 26, 2015 at 5:59 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    It could also be a bad U joint from not using the 4X4 enough.
