Clunking when braking or putting it in reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrankFL., Dec 10, 2022.
  1. Dec 10, 2022 at 4:16 PM
    FrankFL.
    FrankFL. [OP] Well-Known Member
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Hi wanted to.know if anyone had the same problem. I installed a 2 inch lift kit on my tacoma and was working fine. I did not do the aligment for a while. And now i started hearing a clunking when i brake or if i put reverse. I also replaced upper ball joints. I cant figure it out where the noise is coming. I can hear it louder when i put it in reverse and brake. Does anyone had this problem.??
  2. Dec 10, 2022 at 6:33 PM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Check your Universal joints for excess play.
    SethM likes this.
  3. Dec 11, 2022 at 12:50 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    An 06 and what's the maintenance history, mileage, all mods, 2 or 4WD?
