Clunking when going slow and turning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nathanroyse, Jul 1, 2020.
  1. Jul 1, 2020 at 7:50 PM
    nathanroyse
    nathanroyse [OP] Well-Known Member
    Nate
    2019 Tacoma TRD-Offroad 4x4
    Bilstein 5100 w/ OME 887 Springs Bilstein 5160s TRD Pro Grille Method NVs w/ Falken Wildpeaks 265/75/16
    I recently noticed a very concerning creeking to clunking noise when turning at low speeds. Mostly when pulling in and out of the driveway, etc. I’ve looked under the truck multiple times and everything seems to be intact and tightened. It definitely sounds like it’s coming from upfront and I can feel it in the floorboard when it happens. I know taking it to the dealer would probably be the best option, but I’m worried they’re going to try and blame it on my aftermarket suspension. If anyone has had something like this happen and figured it out, please help! Or atleast where I should start...
    Edit: Torqued down LCA bolts and clunking is gone. most of them were tight but there was one that was extremely loose... Everyone check your alignment bolts!
  2. Jul 1, 2020 at 7:51 PM
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    Are you in 4WD?
  3. Jul 1, 2020 at 7:54 PM
    tcjacado
    tcjacado Well-Known Member
    Lca and/or cam bolts are torqued properly?
  4. Jul 1, 2020 at 7:57 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    My sway bar end links loosen up over time and do that.
  5. Jul 1, 2020 at 7:57 PM
    nathanroyse
    Nate
    Not in 4wd. Atleast it doesn’t feel like it’s completely in 4wd. No lights on the dash indicating that it’s in 4wd
  6. Jul 1, 2020 at 7:58 PM
    nathanroyse
    Nate
    I’m not currently running a sway bar:/
  7. Jul 1, 2020 at 7:58 PM
    nathanroyse
    Nate
    Yes. I just got it aligned and told the shop about the sound. Also asked them to make sure everything they did was tight.
    tcjacado[QUOTED] likes this.
  8. Jul 1, 2020 at 8:00 PM
    tcjacado
    Ding.... my bet is on one of those. Most likely the cam bolt not torqued to 100 plus ftlbs
  9. Jul 1, 2020 at 8:03 PM
    nathanroyse
    Nate
    I’ll double check their work. It was happening before I took it in, seems to be a bit worse now.
  10. Jul 1, 2020 at 8:07 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    normal
    boston23 likes this.
  11. Jul 1, 2020 at 8:13 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Turdgen is 135 ft-lbs on the LCA bolts. And it’s not simple to get them to that torque, so guessing a lot of shops don’t get it right. I recently fixed a similar noise by torquing the LCA bolts. Driving up on ramps helps to get some space to crank.
  12. Jul 1, 2020 at 8:13 PM
    nathanroyse
    Nate
    I would like to think it’s normal... but it wasn’t doing this last week.
  13. Jul 1, 2020 at 8:14 PM
    nathanroyse
    Nate
    The shop I took it to was Firestone. Not a super small shop, but I guess that’s a possibility.
  14. Jul 1, 2020 at 8:15 PM
    tcjacado
    Thanks for the correction. I know it's one or the other :cheers:
  15. Jul 1, 2020 at 8:16 PM
    tcjacado
    I am gonna say that's a definite. Lots of us around here have had issues with that chain.
  16. Jul 1, 2020 at 8:19 PM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    I just installed UCA’s and am getting an alignment tomorrow. I’ll check mine as soon as I get home. The driver side front is tough, the nut side sits right by the CV axle and it’s hard to get the wrench in there. That was the one that was loose on mine. Make sure you torque the nut side, not just the bolt side.
  17. Jul 1, 2020 at 8:20 PM
    nathanroyse
    Nate
    Yep. I’ve taken it there 3 times this month and they still can’t get my wheel straight, let alone the camber correct on my wheels... can anyone recommend a good shop in SoCal?
  18. Jul 1, 2020 at 8:21 PM
    nathanroyse
    Nate
    I’ll try. So I have to torque both sides? What UCAs did you go with?
  19. Jul 1, 2020 at 8:22 PM
    tcjacado
    Bear alignment. There are only a handful of good shops. Look these guys up.
    Both locations probably not close. Maybe try the Downey Firestone location.
  20. Jul 1, 2020 at 8:24 PM
    tcjacado
