Clunky disengage
Discussion in 'New Members' started by Kaykip, Dec 13, 2018.
  1. Dec 13, 2018 at 8:24 AM
    Kaykip
    Kaykip [OP] New Member
    2011taco
    None
    Just took my 2011 to the dealer , clunking when 4wd is disengaged. Was told this was normal ....the last time I had a problem I told them it was not steering right.. they put new front brakes and did an alignment ... 2 months later the steering shaft was gone!!!!! So I will just have to drive it till it breaks , hopefully it is normal !
  2. Dec 13, 2018 at 9:50 AM
    MJ-12
    MJ-12 Well-Known Member
    Tee
    Houston, Texas
    2018 Limited 4x4 Mag Grey
    Stock
  3. Dec 13, 2018 at 9:54 AM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW! There is a whole section on 2nd gens and a f ton of other info truck and not truck related. Kick off your shoes and start reading and talk to some members here. ;)
    https://www.tacomaworld.com/forums/2nd-gen-tacomas-2005-2015.5/
  4. Dec 13, 2018 at 9:56 AM
    eon_blue
    Azusa, CA
    A "clunk" when disengaging 4wd and going back into 2wd is completely normal...sometimes it's barely noticeable, sometimes it's rather big and unnerving...it's just the way it disengages. I've found that disengaging while coasting in a straight line is the best way to avoid the clunk, or disengaging while stopped. Avoid turning when doing so. But to a degree it's unavoidable and likely to clunk to some extent most times.
  5. Dec 13, 2018 at 12:34 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    tcjacado, Bigdaddy4760 and irayfz6 like this.
  6. Dec 13, 2018 at 4:31 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
  7. Dec 13, 2018 at 6:59 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW!!
    :hattip: :cheers:
