Clunky front end is worse than I thought...
Discussion in '1st Gen. Tacomas (1995-2004)' started by skedrc, Jun 3, 2019.
  1. Jun 3, 2019 at 11:19 AM
    skedrc
    skedrc [OP] Well-Known Member
    Preston
    Elko
    2005 MT 4wd
    Well, my Taco has had a weird sound coming from the front end recently, I put off looking at it till this weekend and found out that it is worse than I thought. I am not even sure what happened? It appears that the top portion of my shock busted through somehow and it has wore away at where it mounts. Any suggestions on fixing this?
    [​IMG]Untitled by
  2. Jun 3, 2019 at 11:20 AM
    tcjacado
    tcjacado Well-Known Member
    Looks like the top hat is done on the coil over. Needs a new top hat if not a whole new coil over assembly
  3. Jun 3, 2019 at 11:22 AM
    skedrc
    Preston
    Elko
    2005 MT 4wd
    but it also appears that the shock has rubbed a large hole in the upper portion where it mounts from going up and down? Do I need to have someone weld on a new shock mount?
  4. Jun 3, 2019 at 11:42 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Hopefully not. I think as long as the new coilovers mount flush in there, you should be fine.
    tcjacado likes this.
  5. Jun 3, 2019 at 11:47 AM
    tcjacado
    Like I said. Start with a new top hat (minimal fix if in a bind) maybe the full coil over (the proper fix). Do both passenger and driver side. You may need some work on the mount on the frame, but it looks like you caught it early enough.
  6. Jun 3, 2019 at 12:09 PM
    Glamisman
    Glamisman Well-Known Member
    if you have access to a welder you should be able to weld a washer of the correct thickness to the strut mount rather than attempt to fix that wallowed out hole.
  7. Jun 3, 2019 at 12:34 PM
    skedrc
    Preston
    Elko
    2005 MT 4wd
    Welp, I removed the shock and to my disbelief, the hole that got wallowed out wasn't actually in the mount, but in the upper shock ''top hat''. I am not going to attempt to weld it together, just gonna go buy some new shocks. Also, since my truck has a 6 Inch drop bracket lift, will I need a different type of shock other than a OEM? I don't think I do but I am just checking, thanks guys.
  8. Jun 3, 2019 at 2:18 PM
    tcjacado
    I figured as much.
    What do you have in there currently?
  9. Jun 3, 2019 at 2:25 PM
    jbrandt
    Justin
    Pretty sure you can purchase the top hats separately. So as long as your shocks are still in decent enough condition, I'd just go for the top hat replacement.
  10. Jun 3, 2019 at 9:02 PM
    skedrc
    Preston
    Elko
    2005 MT 4wd
    The supplied Fabtech shocks that came with the lift, although I did not install the lift. I purchased the truck and it already had it.
  11. Jun 3, 2019 at 9:15 PM
    tcjacado
    I am not sure Ethier if you need the same shock or not.
  12. Jun 3, 2019 at 9:36 PM
    skedrc
    Preston
    Elko
    2005 MT 4wd
    My current shocks measure 26.5 inches un-compressed... Everything I've just read up and checked OEM shocks says that they are around 18 inches uncompressed.. Any idea where I can snag a 26.5 inch shock at....
  13. Jun 3, 2019 at 9:39 PM
    tcjacado
  14. Jun 3, 2019 at 9:43 PM
    skedrc
    Preston
    Elko
    2005 MT 4wd
    Welp... I am not wanting to shell out a ton of money for Kings... I may contact Fabtech to see if they could get me some replacements...
  15. Jun 3, 2019 at 10:06 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    I remember my grandpa saying something similar to his doctor years ago
  16. Jun 3, 2019 at 10:55 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    @skedrc just so you know there is supposed to be a "hole" in that mounting spot. it allows the top of the coilover to pass through and relies on the top plate to hold the shock
    as others have stated your top plate is probably damaged or worn out (the left side looks rounded out)
