Clunky Shifting 2001 2.7 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by KGN, Apr 24, 2016.
  1. Apr 26, 2016 at 4:42 PM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    Good luck and let us know if you find anything or have any questions.
  2. Apr 26, 2016 at 6:00 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Now your problem "crunchy problem" sounds like bad synchros. My shifter shifts in silky smooth in all the gears 90% of the time.
    The problem that I have (and I think the op) is with the actual clutch. When we let out the clutch, there is a thud or a clunk unless you shift super slow and at the right speed.
  3. Apr 26, 2016 at 6:02 PM
    eon_blue
    Azusa, CA
    I get that too at times, it isn't a loud thud but the more abrupt my shifting is the more noticeable. I should probably take her in for a tranny service, I think the previous owner may have treated it rough with the supercharger.
  4. Apr 26, 2016 at 6:47 PM
    KGN
    KGN [OP] Well-Known Member
    2011 Tacoma 2.7L
    I would say that's a fairly accurate description of what happens for me. I do the brakes tomorrow night, then after this weekend I'm going to try the fluids and see if that helps at all. I want to change them out anyways as regular maintenence to my new to me truck. I want to keep this thing running sweet.
    Since I have got it I've changed the oil, greased everything that's greas able, cleaned the MAF and changed the plugs. Going to peek at the throttle body tonight.
    DustStorm4x4[QUOTED] likes this.
  5. Apr 27, 2016 at 7:37 AM
    KGN
    2011 Tacoma 2.7L
    So after looking again I don't have any movement in the u joints, but I was looking at the carrier bearing (I think?) and I am curious what is a normal amount of play their. I'm unsure if a worn carrier would cause that symptomn or not. I'm thinking deep down that it's probably something to do with the clutch, I'm just trying to put my head in the sand...
    Again thanks for the help here, great info.
    Unrelated but I did the throttle body clean last night. Was pretty dirty in there. Would like to take it off completely next time I clean it, but I noticed truck is more responsive. Idled high for a bit, seems to be back to normal now.
  6. Apr 27, 2016 at 9:56 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's just how you have to shift with them if you're new to it, slow but steady. When you become good at that you can go faster and it won't be clunky. Or you can learn to drive stick on an unsynchronized dump truck and shift clutchless or double clutch. I wouldn't recommend clutchless unless you're really good though, it'll eat the synchros. The fluid in the gearbox won't change how you handle the clutch which sounds like OPs issue. If your used to sporty cars it's just gonna take time. Took me a while to get used to it, but now I can row the gears really fast without jerkiness. You're clutch might be heavily worn which will have the engagement point super high which many aren't used to as well.
  7. Apr 27, 2016 at 10:53 AM
    KGN
    2011 Tacoma 2.7L
    Could be the way I'm shifting it, but I think there is more going on. Whether its worth worrying about I'm not sure. I have driven other tacomas, but not another 2.7. I didn't seem to have any issue, I have driven standards all my life. And my work truck is a diesel 550 loaded with a couple hundred gallons of water, chainsaws, hand tools, hose ect. It shifts smoother.
    I did read other posts about changing the gear fluids helping, but maybe not for this. Worth a shot anyways.
  8. Apr 27, 2016 at 11:31 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Don't forget that the diff in that back takes a gl5 gear oil. While the transfer case and transmission are gl 4.
  9. Apr 27, 2016 at 6:27 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    That's not true. The manual calls for gl4 or gl5.
    Some people say gl5 will be hard on the syncros in the trans, but that seems to be a myth.
  10. Nov 7, 2016 at 1:50 AM
    JAMEDYota
    JAMEDYota Active Member
    I have a very similar issue in my 99 2WD 2.4l w/ 152K... One afternoon just would not shift into 1,3,5. Or would barely go into gear and immediately pop out when releasing the clutch. Changed out the the shifter seat bushing and fixed that right away, cost about 10 bucks. Shifted better and went into every gear but still feels notchy. So I changed my fluid with Redline 75w90 GL4 expensive synchro friendly fluid (NOT CHEAP BTW) but made ZERO improvement.
    I'm considering either a whole new clutch and flywheel and/or master and slave cylinder because I want that smoother shift and engagement back. Haven't decided which one to do first or which is most likely going bad.
    My advice, don't bother changing your fluid unless you change your clutch/flywheel as it only lubricates the gears and doesn't provide pressure assistance. Most likely will not help with the problem you're describing, at least it didn't work for me. Rather keep troubleshooting and if it leads to a clutch replacement, then change your fluid to the Redline Gl4 because your going to have to drain it anyway when you drop the tranny. If you have to fill it twice with Redline Gl4 (like I'll probably end up doing now) its gonna cost almost $100 or more just in fluid!
