Cluster Replaced, and now Warning lights.
Discussion in '1st Gen. Tacomas (1995-2004)' started by garrettnb, Jan 8, 2012.
  1. Jan 8, 2012 at 3:59 PM
    garrettnb
    garrettnb [OP] Canadian Ambassador
    Garrett
    Vancouver
    00 TRD w/33s on a 4" lift
    When I bought my taco a month ago one of the things I new going into it was that the speedometer didn't work. There was a quote from a dealership from 4 years ago that said it needed a new dash unit. Unfortunately driving an american truck in Canada nobody knew exactly what putting the metric unit would do in this truck (the odometer being the issue here, not the speedo obviously). Anyways I finally tracked down a new cluster in the states and had it shipped here, luckily for me it also has a tach where as my old one did not. I got it all installed and it works great, except that the ABS light now stays on. What could this mean? I don't even know if I have ABS, What would be the easiest way to find out?
    The old and the new
    All installed!
  2. Jan 8, 2012 at 4:02 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    take a picture under your hood on the passenger side i believe. If you have abs there will be a box with bralke lines running to it. It would be beside the cruise control if you have that option. If you do not have abs I would just pull the bulb.
  3. Jan 8, 2012 at 4:32 PM
    garrettnb
    Garrett
    Vancouver
    Would be here if I had it?
  4. Jan 8, 2012 at 4:35 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Yeah your 00 didnt come with it, they were standard starting in 01 , just pull the bulb from the cluster and call it a day. :)
    I have a cruise control in that area as well.
  5. Jan 8, 2012 at 4:40 PM
    garrettnb
    Garrett
    Vancouver
    Thanks! I'll be pulling the bulb then.
  6. Jan 8, 2012 at 4:57 PM
    2000GTacoma
    Snow Hill NC
    sounds good
  7. Feb 8, 2013 at 9:08 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    I don't have abs, and am looking to do a cluster swap. About where on the back of the cluster did you pull the bulb?
  8. Feb 8, 2013 at 11:09 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    remove the whole assembly and remove one bulb at a time and hold the assembly up to the light. you can see the outline of what the bulb would have lit up. hard to explain, but once you see it, it'll be obvious.
  9. Feb 9, 2013 at 8:19 AM
    garrettnb
    Garrett
    Vancouver
    If I remember correctly it's even easier than this. I'm pretty certain that the back of the cluster is labeled with ABS. That being said, it's pretty straight forward as there aren't that many bulbs.
  10. Feb 9, 2013 at 5:35 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    Does the odometer work correctly in the "new" cluster you installed? I didn't think the "new" style cluster with the electronic odometer would work for vehicles that were not previously equipped with an electronic odometer. Your "old" cluster did not have the electronic odometer.
  11. Feb 10, 2013 at 3:40 AM
    garrettnb
    Garrett
    Vancouver
    You are correct, my previous cluster did not have the digital readout for the odometer. But the new one does have it and it does work. I can't remember which year they changed from mechanical to electronic speedo - you have a 1995? This seems to be on the early end in my mind. Best to pull the cluster from your truck and check the connections.
  12. Feb 10, 2013 at 9:26 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    95-97 was the cable style, 98+ is electronic.
