Clutch adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09_xrunner, May 29, 2022.
  1. May 29, 2022 at 4:05 PM
    09_xrunner
    09_xrunner [OP] Member
    Jeff
    2009 Black Tacoma Xrunner
    Pretty much stock
    Anyone have a PDF for adjusting the clutch pedal, don’t really care to try to figure it out myself by tinkering…
  2. May 29, 2022 at 4:13 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The official FSM basically states upper and lower limits then says figure it out by tinkering so dunno what you're really going for here.
    There's not much in the way of adjustment, you loosen the nut on the MC shaft and turn the shaft up or down, there is no actual adjustment of the clutch.
    So long as the engine is decoupled fully from the trans through the clutch when the pedal is down you're about as adjusted as you can get.
    The rest is just positioning for comfort really.
    You can get a little better pedal position by doing the FJ cruiser steel pedal swap but that requires a couple parts and potentially a little spot if weld.
  3. May 29, 2022 at 4:16 PM
    09_xrunner
    Jeff
    Pretty much stock
    I’m trying to preload my bearing to stop the idle squeak is all.
  4. May 29, 2022 at 4:20 PM
    09_xrunner
    Jeff
    Pretty much stock
    Hey thanks man, that’s what I needed!
    Black DOG Lila likes this.
  5. May 29, 2022 at 4:20 PM
    Key-Rei
    Key
    Florida
    You can't really do that from the pedal unfortunately due to how the system is designed.
  6. May 29, 2022 at 4:23 PM
    09_xrunner
    Jeff
    Pretty much stock
    Yeah actually you can. It’s just a matter of knowing what your doing once you know the system. I’ve just never messed with this system before…
  7. May 29, 2022 at 4:24 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
  8. May 29, 2022 at 4:25 PM
    Key-Rei
    Key
    Florida
    Okay, good luck have fun let me know how that works out for you.
    Reggie4x4 likes this.
  9. May 29, 2022 at 4:26 PM
    Key-Rei
    Key
    Florida
  10. May 29, 2022 at 4:27 PM
    09_xrunner
    Jeff
    Pretty much stock
    I don’t care about your buddies opinion man, I’ve been turning wrenches long enough to know… I’ve got what I need I don’t care about your opinion, I asked for a pdf and got that’s all I needed.
  11. May 29, 2022 at 4:30 PM
    Key-Rei
    Key
    Florida
    Okay Jeff not like I used to be a Toyota tech or have taken hours of my own life to attempt to reverse engineer this stupid system (hence my FJ cruiser pedal shenanigans) or anything.
    I was simply tagging Gearcruncher in the off chance case I was wrong or he knows something special because there's always room to learn new things but if you like doing it the hard way by all means only trying to help.
    Good luck have fun.
    gearcruncher likes this.
  12. May 29, 2022 at 4:34 PM
    09_xrunner
    Jeff
    Pretty much stock
    But you didn’t help, you just gave me grief. I asked for something specific, and I got a run around from you. You can leave now.
  13. May 29, 2022 at 4:37 PM
    Key-Rei
    Key
    Florida
    Thanks for the permission!
    :rolleyes:
  14. May 29, 2022 at 5:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    blu92in99, Key-Rei[QUOTED] and Dm93 like this.
  15. May 29, 2022 at 5:42 PM
    Key-Rei
    Key
    Florida
    Yeah that's the thread that I had in mind and it basically says what I remembered; it can't be done.
    In the very least it certainly can't be done by pedal adjustment, I suppose you might be able to make a 1/16" or 1/8" shim for the bell housing if you want to go that route but no telling what all cascade implications that would have.
    Irregardless, you can't help those that don't want to be helped so as far as OP goes: set to ignore; I'm done wasting my time.
    :p
    Jimmyh and TnShooter[QUOTED] like this.
  16. May 29, 2022 at 9:25 PM
    09_xrunner
    Jeff
    Pretty much stock
    Good, please go. You weren’t helpful.
  17. May 29, 2022 at 9:45 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Why the hostility Jeff?
  18. May 30, 2022 at 12:02 AM
    Key-Rei
    Key
    Florida
    $yoda$ and winkel like this.
  19. May 30, 2022 at 7:20 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Not doubting your mechanical abilities but you really should read through the link about clutch adjustment. I believe what you are trying to do will work in quieting your chirp, but it will drastically shorten what life you have left in the TOB.
    Those bearings weren't designed to spin all the time.
    b_r_o, TnShooter, $yoda$ and 2 others like this.
  20. May 30, 2022 at 9:34 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Key-Rei likes this.
