Clutch and Transmission Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by mcariveau, Dec 12, 2022.
  1. Dec 12, 2022 at 7:06 AM
    mcariveau
    mcariveau [OP] Member
    Michael
    1998 Tacoma
    standard 4 cylinder with 5 speed transmission
    Hi Guys,
    New to the forum, thanks for having me. I have a question. I have a 98 tacoma, standard cab with 209K miles. Has been perfectly fine but I got in it last night and the clutch went all the way to the floor and it would not go into any gears. I started it and eventually was able to force it in gear but it was not smooth at all. This just happened and has not been a problem in the past. Any ideas? I would say master or slave cylinder if it was just the clutch with no pressure but the transmission shifting has me stumped. Any help would be most appreciated,
    Michael
    Black DOG Lila likes this.
  2. Dec 12, 2022 at 7:18 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Probably either the master or slave, but at that milage I'd just replace both. Theres a slight chance the shift fork could be broken. I would get under the truck and watch the slave cylinder on the drivers side of the bellhousing as a helper presses on the clutch, it should give you some insight into the problem.
    The reason you can't shift is because the rotation of the engine is 'binding' (for a lack of a better word/coffee) the transmission. When you press the clutch, it disconnects the engine from the transmission and removes strain from the transmission and allows you to shift. Having a clutch that wont' release prevents this from happening.
    wilcam47, TForan and Black DOG Lila like this.
  3. Dec 12, 2022 at 7:37 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Is the fluid BLACK ?
    Use a turkey baster to drain the MC and fresh DOT3-4 sometimes fixes it.
    Broken fork ?
    Pedal mounts on firewall cracked ?
    Shifter seat and bushing worn out/broken ?
    Good luck :fingerscrossed:
  4. Dec 12, 2022 at 7:42 AM
    mcariveau
    Michael
    1998 Tacoma
    Thanks for the suggestions Black DOG Lila, I will check all of these when I get home today.
  5. Dec 12, 2022 at 9:25 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If your clutch release Fork failed the slave cylinder might also have shot the piston out when pressure was applied .
    Also causing Hydraulic Failure as well.
  6. Dec 15, 2022 at 4:46 PM
    mcariveau
    Michael
    1998 Tacoma
    Problem solved, just had to add some fluid to the cylinder. Thanks for your help.
  7. Dec 15, 2022 at 6:10 PM
    0xDEADBEEF
    Hmmm. Any idea where it went before?
    Bivouac likes this.
  8. Dec 15, 2022 at 6:16 PM
    Bivouac
    Very interesting !
    Unless the reservoir was empty it would not allow the clutch to go to the floor.
    So just where has the fluid run off to is the question??
