clutch belt squeaking?
Discussion in 'Performance and Tuning' started by jasonm, Mar 2, 2010.
  1. Mar 2, 2010 at 7:46 PM
    jasonm
    jasonm [OP] Member
    Virginia
    07 TRD Sport
    Truxx Leveling Kit, 285 70 R17 MTR's, K&N Intake, Throttle Body Spacer, Pioneer Touchscreen Media Player.
    i was wondering if anyone knows what this problem might be. it sounds like a belt squeaking under the hood and when i push the clutch pedal in, it tightens up and the squeak goes away. is this my throw-out bearing or is this just a belt that i can tighten? any info is greatly appreciated, thanks.
  2. Mar 2, 2010 at 7:52 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    sounds like the TO bearing. Some folks have had problems with them. Try a search in the 2nd gen forum. It would also help to know what engine/tranny you have
  3. Mar 2, 2010 at 8:02 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    could either be the clutch belt or possibly the muffler bearings. being that it goes away when press down the clutch pedal, my guess would be the pressure plate's torque band has been stretched a bit. Would be a good place to start. :thumbsup:
    /helpfulness
  4. Mar 2, 2010 at 8:05 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    my supercharger belt does it for like the first 90 seconds when the car warms up, but on my jeep the TO berring squeeked when it was going out
  5. Mar 2, 2010 at 10:21 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    clutch belt huh? ha. got my attention. anyway it sounds like you are a pround new member of the defective throwout bearing shaft club! I am a founder, so welcome! check out http://www.tacomaworld.com/forum/2nd-gen-tacomas/58278-tsb-t-o-bearing-issue.html. Everything's in there about it. Oh, and if youre looking for the solution..... there isn't one... just put the defective setup back in and wait till it goes again.... hopefully someone will come up with something better soon. good luck!
  6. Mar 2, 2010 at 10:28 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Did someone say, Muffler Bearing? :spy:
    In all seriousness, it sounds like you a have a problem with the throwout bearing. A well documented problem with the 2nd gen 6 speeds.
  7. Mar 3, 2010 at 2:07 AM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    HAHAHAHA! thats mean. make sure the blinker fluid is topped off also!!! fender gaskets also cauz a squeek from time to time
  8. Mar 3, 2010 at 2:08 AM
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    u need a urd pully mine never sqeeks
