Clutch Burning, in reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ijonahtacoma, Aug 28, 2018.
  1. Aug 28, 2018 at 4:30 PM
    ijonahtacoma
    ijonahtacoma [OP] Well-Known Member
    Jonah
    2005 Black Tacoma with the turtle shell
    Seriously I'm just learning how to work on this thing.
    Hi y'all,
    2nd gen taco, 2005 v6 6 speed manual.
    Anytime I have to use reverse slowly, like into a tight spot, I get a pretty bad burning smell. It happens if I have to pump the gas/clutch to ease the truck into the spot. It also occurs if I have to reverse up and incline, slowly.
    Does anyone else experience this? Curious if it could be *normal*. Transmission doesn't slip, and it only happens in the situation described above.
    Any experience? Am I going to need a new clutch soon? Should I point-blank avoid using reverse like this?
    Thanks for your input!
  2. Aug 28, 2018 at 4:43 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    To low numerically gear in the transmission and axle compounded with too tall of tire and I bet this happens on steep parking lots
  3. Aug 28, 2018 at 4:46 PM
    Pigpen
    Dan
    Northwest Montana
    Its because you're intentionally slipping the clutch. We all have to do it, since reverse is geared so high. I installed the @Up2NoGood 2wd low range mod to help with this issue. Possibly the best (out of very many) mod on my truck.
    Hartford and Up2NoGood like this.
  4. Aug 28, 2018 at 4:49 PM
    ijonahtacoma
    Jonah
    180,000 miles. I don't know if the clutch is the original. Probably? I don't have all the service records from the original owner.
  5. Aug 28, 2018 at 4:50 PM
    ijonahtacoma
    Jonah
    Ok, thanks for the tip.
  6. Aug 28, 2018 at 6:14 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Thanks for the shoutout. Just sold one earlier today to a guy with a roasted clutch
    Pigpen[QUOTED] likes this.
