Clutch cancel button as fuel pump kill switch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Darce, Apr 1, 2025.
  1. Apr 1, 2025 at 2:36 PM
    Darce
    Darce [OP] Well-Known Member
    2003 Tacoma
    Would it be possible to use a clutch cancel (latchable relay) button as a fuel pump kill switch?
    Just looking for ideas...
    Clearwater Bill likes this.
  2. Apr 1, 2025 at 4:09 PM
    02hilux
    Planet: EARTH
    IMO, a kill switch should be discrete. Not saying the clutch cancel isn’t but it’s just too obvious. Someone who starts the truck by depressing the clutch pedal can easily press the button if they were lazy to step on the pedal. Just saying…
    MadNachos likes this.
  3. Apr 1, 2025 at 5:05 PM
    Darce
    2003 Tacoma
    I don't have a clutch, I would delete the wording on the switch as well and change it to something else.
    I was just trying to think of something that would look factory. Not many people would think to hit a fog light button to start a truck...
  4. Apr 1, 2025 at 6:39 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    An alarm with ignition kill isn't a bad option.
  5. Apr 2, 2025 at 8:33 AM
    HoneyBadger153
    HoneyBadger153 Well-Known Member
    Lowcountry, SC
    2002 Lunar Mist Tacoma SR5 4WD
    ARB, Hella FF75, SoftTopper, Power Limited Seats, OME Suspension, Heated Mirrors
    +1 for discrete switch. If you have a manual or 4wd shifter, there's some leather that could prove useful - there's also the rectangle knockout panels on the lower garnish that fit buttons from other Toyota cars from that time period (Rav4, Camry, etc) and act as standard toggle switches. You could also look into the StarterStopper - you can program it with multiple switches like a "code" that once done in the correct order will enable the fuel pump/starter.
    I've been looking at doing something like a killswitch, however the RS3200 (if installed on your car) manual states on pages 4 & 5 that it disables the starter if the alarm is triggered and not disarmed with the remote. Also that it prevents hot-wiring which is neat. I should probably confirm that first part on mine though, otherwise yeah kill switch is next to do.
  6. Apr 2, 2025 at 9:16 AM
    02hilux
    Planet: EARTH
    Like this clip, if they really want it, they’ll towed it.
    HoneyBadger153 likes this.
  7. Apr 2, 2025 at 9:30 AM
    HoneyBadger153
    Lowcountry, SC
    Jeez I guess the best way to stop that from happening is take the wheels off and put them indoors lol. That's someone who's been casing their house though. Not a random act
  8. Apr 2, 2025 at 9:45 AM
    02hilux
    Planet: EARTH
    definitely not. they saw what they want and the opportunity presented itself. You can add all the kill switch, club lock, etc but it’s just a deterrent. Won’t stop thieves if you have what they want. My understanding is, the truck was towed down the street and loaded to a trailer. 99.9% of the time, its gone forever. It’s not like they want a joy ride car from point A to point B. If they’re going that far, everything will be removed.
