Clutch cancel switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2Airheads, Mar 25, 2017.
  1. Mar 25, 2017 at 5:05 AM
    2Airheads
    2Airheads [OP] Well-Known Member
    George
    2017 SR AC 4x4 Manual
    Am I hurting anything if I use the clutch cancel switch to start the truck?I read the manual and it states not to use it for normal engine starting. I used it a couple of times to warm the truck up in the morning.
  2. Mar 25, 2017 at 5:12 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Mar 25, 2017 at 5:24 AM
    cseigh
    cseigh It's time for the smug face!!!!
    Carter
    Eastern NC
    '17 TRD OR DCSB 6MT MGM
    Nope, I do the same thing all the time. Just check to make sure it is in neutral first!
  4. Mar 25, 2017 at 5:33 AM
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    Driven manual Toyotas for several hundred thousand miles and always used clutch start cancel when cranking the truck from outside the vehicle. As mentioned, just make sure and confirm neutral before you do it.
    nevadabugle likes this.
  5. Mar 25, 2017 at 5:39 AM
    2Airheads
    George
    Sounds good thanks for the replies.
  6. Mar 25, 2017 at 5:39 AM
    2Airheads
    George
    One more question. Do you leave your in neutral or first gear when parked?
  7. Mar 25, 2017 at 5:59 AM
    thdrduck
    thdrduck Well-Known Member
    1st usually without the brake set... need to change that habit.
  8. Mar 25, 2017 at 6:00 AM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    In gear only when on steep hills.
    But I have a habit of using clutch start cancel as well, so i can be sure daily that I don't have to check or worry about being in gear.
  9. Mar 25, 2017 at 6:05 AM
    CZ5ANM Taco
    BC, Canada
    Some drum brakes use reverse to set the brake adjuster, Others use the ebrake to set them.
    I have no idea how toyota does it on these Gen 3's
    Anyone seen it with their own eyes yet?!?
  10. Mar 25, 2017 at 6:34 AM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    If you use it, cruise does not work.
  11. Mar 25, 2017 at 6:49 AM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    the clutch start cancel comes extremely handy if you are wheeling and stall your truck right in the middle of a climb.
    shakerhood likes this.
  12. Mar 25, 2017 at 6:52 AM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    What??
  13. Mar 25, 2017 at 6:56 AM
    shawnMc
    shawnMc Well-Known Member
    Shawn
    Santa Barbara
    2009 Tacoma regular cab 4x4
    It will burn out your starter if you use it too much
  14. Mar 25, 2017 at 6:59 AM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    shawnMc I believe that they are talking about using the button to start the truck in neutral without getting into the truck.
  15. Mar 25, 2017 at 7:15 AM
    evilfij
    If you start the truck with clutch cancel, the cruise control does not function for that drive.
  16. Mar 25, 2017 at 7:53 AM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    ALWAYS put it in either 1st or reverse depending on the grade. Seriously, there's NO valid argument for not parking in gear aside from laziness or ignorance.
    Or just test your luck without it and risk finding that your truck had slowly creeped its way out of a parking spot.
    Never understood why so many people with auto transmissions don't use the parking brake and so many people with manual transmissions refuse to keep it in gear.
  17. Mar 25, 2017 at 8:25 AM
    2Airheads
    George
    I always park in gear.I was just asking what others did.
  18. Mar 25, 2017 at 8:57 AM
    Paterico
    San Antonio, TX
    Good. Wasn't trying to come off a certain way, I just learned this lesson the hard way many years back.
    05 Honda S2000, parked in neutral in a spot with a very slight incline. Came back and my car was halfway backed out of the spot. Could have been WAY worse and rolled out into traffic.
  19. Mar 25, 2017 at 6:34 PM
    WOTaco
    Pretty sure mine does. I'll confirm tomorrow.
  20. Mar 25, 2017 at 7:14 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I always leave my vehicles in gear when parked.
