Clutch/Clutch hydraulic problems...any insight appreciated
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMX, Feb 26, 2013.
  1. Feb 26, 2013 at 2:25 PM
    TacoMX
    TacoMX [OP] TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Having this issue w/ my clutch that I thought I fixed last year.
    What its doing: When using the clutch to start/stop, or just resting your foot on the clutch pedal with medium pressure, the clutch loses resistance and the pedal falls to the floor....and if its in gear the clutch will engage super close to the floor.
    Then just letting go of the pedal, it will build pressure back up and will feel normal till you use it, or hold it in for too long.
    It did the same thing about a year ago, and after rebuilding the slave, and replacing the master cylinder w/ a unit from autozoneit was fine. But now its doing it again. I replaced the slave yesterday, and after bleeding the clutch...and there is NO AIR in there...still doing the same thing. There are no external leaks anywhere.
    Tired of this...could it be anywhere else in the clutch system that could be causing this? Should I take the master cylinder back under warranty and replace it again too?
  2. Feb 26, 2013 at 2:29 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
  3. Feb 26, 2013 at 5:54 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    sounds like your master cylinder is bad.
  4. Feb 26, 2013 at 5:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  5. Feb 26, 2013 at 9:10 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I've had bad luck with aftermarket and only use factory replacements now. They're really not that expensive and you' prob. get 10 years service from it.
  6. Feb 26, 2013 at 9:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I replaced my master and slave cylinders on my 1986 Toyota with NAPA parts. I used the lifetime warranty probably four times in the following six years/ 50,000 miles or so.
    I agree, dealership is the right choice for these particular components.
  7. Feb 27, 2013 at 12:06 AM
    TacoMX
    Jonathan
    Deltona, Florida
    I'm probably going to give the autozone master cylinder with the lifetime warranty and all...and after that probably will give an OEM unit if it gives me more issues.
  8. Feb 27, 2013 at 5:45 AM
    C O R E
    C O R E Christian Off Road Engineering
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Line-X bedliner, bedlined toolbox, Satoshi Grille, bedlined stock old school wheels, Pioneer DEH-X9500BHS head unit, Deck plate mod, ISR mod, K&N Drop-in, Thrush muffler dumped @ rear axle, Grey wire mod, +5mph fender stripes
    Just bought my '03 3 weeks ago brought it home and it drove nice for about 2 days then started having the same symptoms as yours.
    seemed as if the clutch system had never been bled/flushed/refilled/replaced as dirty and nasty as it was, and the little rubber cap for the bleed valve was fused to the valve because of dryrot.
    I flushed the system, refilled, removed enough air to inflate the Hindenburg and it shifts better than the day I got it.
    I agree with others that if you aren't rocking an OEM system, that has to be the problem. Fluid is backwashing thru a weak seal in the cylinder giving your clutch half of it's normal cycle thus causing the pedal to engage at the floor versus mid/top end. That, of course, is my agressively unprofessional opinion however. I have zero mechanical experience just using common sense of a hydraulic circuit.
