Clutch creak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ikillterrorists, Jan 4, 2011.
  1. Jan 4, 2011 at 10:08 AM
    ikillterrorists
    ikillterrorists [OP] Well-Known Member
    Andrew
    New Paltz, NY
    Sold my tacoma, got a Dodge Ram
    TRD Cold air intake Aries Grille Guard Flowmaster American Thunder Dual Exhaust Pro comp 3" suspension lift KMC XD Hoss, BFG KM2 285/75/16 Hypertech Speedometer Calibrator N-Fab Side Steps Access Roll-Up Cover TRD Quick Shifter SafeHitch
    I've been bugging the dealership about the clutch pedal squeak problem for several months, and they haven't been able to fix the problem. Today they said that Toyota corporate is supposedly finally working on getting a solution for it soon. Who knows.
  2. Jan 4, 2011 at 10:10 AM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    yeah mine does that too
  3. Jan 4, 2011 at 10:11 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    The service manager at the dealership also decided to close my Reviewing Order (RO?), and said that there was "no problem found." When I called him he said that Toyota is "aware of the problem" and that everything "will be taken care of."
  4. Jan 4, 2011 at 10:12 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    My solution = a shot of white lithium grease every few months during the warm months. It doesn't really squeak during the cold months.
  5. Jan 4, 2011 at 10:12 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I had that years ago. I oiled the metal shaft that's depressed when you step on the clutch and it solved the problem for me.
    Get your head under the dash and look around.
  6. Jan 4, 2011 at 10:16 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Tighten the nut below that metal shaft. Squeak/creak will be gone.
  7. Jan 4, 2011 at 10:24 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    I think I'm going to try different kinds of grease. "Toyota's" grease didn't work, neither did WD-40.
    Tightening the nut only works for like 5 minutes. Oh yeah and mine squeaks in cold weather too.
  8. Jan 4, 2011 at 10:25 AM
    numbah57
    kahai
    Maui, Hawaii
    Huh, the nut tightening thing works for months on my truck.
  9. Jan 4, 2011 at 10:27 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    Wait what do you mean by tightening? Not just turning the entire shaft?
  10. Jan 4, 2011 at 10:31 AM
    numbah57
    kahai
    Maui, Hawaii
    I spin the nut counter clockwise by hand as tight as I can get it. I've tried using pliers but it's a tight fit. Spinning the nut clockwise pushes the shaft thingy against the pedal more snug so there's no squeaking as the pedal slides on the shaft.
  11. Jan 4, 2011 at 10:33 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    Hmm when I turn it as far as I can, it always turns back by itself once the clutch is depressed. Maybe I'm just not turning it hard enough.
  12. Jan 4, 2011 at 10:35 AM
    numbah57
    kahai
    Maui, Hawaii
    Try to get pliers or a wrench in there and crank on it. Mine also spins back a little but not to much.
  13. Jan 4, 2011 at 10:56 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Mine squeeks too but has been good since it got cold out. Dealer has greesed it a few times now. Almost as anoying and now replaced by the fan motor squeek. I guess one relieves the other and I get no relief.
  14. Jan 4, 2011 at 11:00 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    My '09 had this problem. Grease it, tighten the nut... it eventually comes back.
  15. Jan 4, 2011 at 11:02 AM
    numbah57
    kahai
    Maui, Hawaii
    Every couple of months I have to re tighten the nut
  16. Jan 4, 2011 at 11:10 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    You guys should also email Toyota corporate
  17. Jan 5, 2011 at 8:27 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    What kind of grease should I use?
  18. Jan 5, 2011 at 8:36 AM
    mjp2
    NJ
    I just dribbled some 10w-30 on there.
  19. Jan 6, 2011 at 6:29 PM
    ikillterrorists
    Andrew
    New Paltz, NY
    Sprayed a tiny bit of white lithium grease, squeak is all gone! And the pedal even FEELS smoother now too.
    Suck it, toyota dealership! Who needs you when there's tacomaworld.com?
  20. Jan 6, 2011 at 6:37 PM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    My 2010 had 4950 miles on it when I took it in for it's first free service. When I walked into the service department, the first thing I mentioned to the service manager was that my clutch pedal squeaked. The response I received from the service manager made me quickly realize that I had an endless battle ahead of me. I will deal with my squeaky clutch pedal another time, it is quiet now thanks to the cold weather. If it annoys me again this summer I may complain to the service department again.
