Clutch doesn’t seem to slow engine…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wyofishtaco22, May 28, 2022.
  1. May 28, 2022 at 9:41 PM
    Wyofishtaco22
    Wyofishtaco22 [OP] Member
    Wyoming
    2022 Manual TRD Off Road Silver Tacoma
    2022 MT 6 speed Tacoma
    At times when engaging the clutch to shift there is the slightest whir felt in the clutch (similar feeling to that when you try to completely engage/push clutch and accelerate at the same…yes I understand that that should never be done just remember that from learning to drive MT). It gets a little better if I wait a little longer between disengaging accelerator and engaging clutch but that makes for slower and more awkward shifting. The feeling is almost as if the clutch is not slowing the engine down when engaged and therefore I can slightly (and I mean barely at all) feel the engine through the clutch. No weird noises (except the fact that the engine seems sound like it maintains high rpms even with the clutch all the way to the floor) nor smells. Typically happens 2-6.
    Is this what they refer to as rev hang? Is there anything that can be done to avoid it?
  2. May 28, 2022 at 9:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yeah, sounds like rev hangs to me.
    I think you can have it “tuned” out. But that involves tuning and flashing the ECM.
    Wyofishtaco22[OP] likes this.
  3. May 28, 2022 at 10:01 PM
    Bishop84
    Bishop84 Well-Known Member
    Tacoma uses rev hang when the catalytic converters are cold, its annoying but part of many modern manual vehicles.
    jmneill, RustyGreen, Kev250R and 3 others like this.
  4. May 28, 2022 at 10:05 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    You'll eventually get used to it and forget about it altogether.
    My 2017 does it, and I'm used to it.
    One thing I may be doing now, is not revving as high between shifts.
  5. May 28, 2022 at 10:06 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I figured if it doesn’t hang the engine would bog out at too low of an rpm. But it’s annoying
  6. May 28, 2022 at 10:17 PM
    Wyofishtaco22
    Wyoming
    Ok i will try and shift sooner…or in other words shift at lower RPMs and see if I notice a difference. Thanks for the help.
  7. May 28, 2022 at 10:18 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I know not what horrible ailment you guys speak of…
    give me until tomorrow when I drive again and and I’ll come back here and join the misery and complaints once I realize how horrible these tacos are…
    :D
    *No but seriously, I do not have this experience…
    Might your clutch need some adjustment?
  8. May 28, 2022 at 10:59 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I think you’ve driven a lot of random crappy vehicles, no offense, but you’re not as picky as some of us.
    INSAYN likes this.
  9. May 28, 2022 at 11:10 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Rev hang. It usually happens at sub 2500rpms when going from 1st to 2nd. Also happens in all other gears. Usually, I wait about 1-2 seconds before clutch in. I believe this is done for emissions, and also I heard that rev hang helps prevent or reduce oil burning from high vacuum.
  10. May 29, 2022 at 8:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    RevHang happens regardless of engine temp.
    doublethebass likes this.
  11. May 29, 2022 at 3:50 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    It seems like the rev hang exclusive to when the engine is in the higher range of rpms, like it has something to do with the Atkinson cycle and the direct injection systems. I only seem to experience it when I getting on it.
  12. May 29, 2022 at 4:44 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is not when I get it. But, it does respond to a certain set of parameters. Hopefully vF Tuner finds the solution. It is greatly lessened in the Ultimate / EROM 1.2 test tune that I had.
  13. May 29, 2022 at 4:47 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I just learned not to get in a hurry with my shifts and it's not an issue. Annoying, but not a problem.
  14. May 29, 2022 at 4:51 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    There is nothing wrong with it.
    It's just a feature. :thumbsup:
    I still haven't felt the need for the accumulator delete mod or a tune, just because it's all the rage on the internet. o_O
    Junkhead and gudujarlson like this.
  15. May 29, 2022 at 8:29 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I am on the adm and a tune and tried to convince oztrd too. He drove my truck and he said he felt very little difference. The adm is really nice though, as well as a tune.
  16. May 29, 2022 at 8:31 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I tried to get it to hang when I left a stop light today (in a 55 zone) but my music was cranked and I couldn’t hear it well enough nor could I feel it.
    tonered[QUOTED] likes this.
  17. May 29, 2022 at 9:15 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Nice, maybe.
    Necessary? Highly unlikely.
    I haven't found a situation in 5 years with mine where I "need" either tweak. Nor a super charger, or a turbo.
    I must have lucked out an got a "built on Wednesday before lunch" truck.
    It's too bad the rest of you have to go through this pain of retuning your trucks and eliminating some parts to get the truck to perform properly.
    :brianr:
    Benny blanco[QUOTED] likes this.
  18. May 29, 2022 at 10:46 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It’s probably just the way you word it but the pressing in the clutch (disengaging the clutch) does not cause the engine to “slow down”. In fact it has the opposite effect and reduces load on the engine by disconnecting it from the driveline that is slowing the engine down.
    DanoTay and gudujarlson like this.
  19. May 30, 2022 at 6:50 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Ignorant thinking, no.
    Practical thinking, yes.
    If you feel that a tune or accumulator delete makes your MT drive SO much better, then you clearly felt it was lacking something. Or, you just followed the crowd with "Monkey See - Monkey Do".
    I don't feel that my truck is lacking anything in either department, so I have no interest in changing either of those items. That's five years of seat time in this truck on and offroad.
    Same with my '97 Taco. Purchase brand new as well and now 25 years and over 255k miles of happy stock motor, and only one clutch replacement, it drives just fine to me as well.
    If it ain't broke, don't fix it. :cheers:
    Junkhead likes this.
  20. May 30, 2022 at 7:13 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have noticed this rev hang, but it has never bothered me much. It does not affect the way I drive. I assume it’s there for a purpose and common to modern engines with a manual, but I haven’t driven any of them. My previous automobile with a manual was a 2001 Subaru and it didn’t have such a pronounced rev hang as I remember.
