clutch/electrical issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by resinball, Nov 14, 2020.
  1. Nov 14, 2020 at 6:17 AM
    resinball
    resinball [OP] Active Member
    Having an issue with my 2019 trd pro where whenever I push the the clutch to the floor to start the truck or to shift gears I lose power to the center multi information display and the rpms drop to the point I almost stall when at a complete stop. I checked the function and movement of the pedal to see if it might be a wire or something being pinched and discovered nothing. But if I depress the sensor ( not the clutch start cancel switch ) on the floor that registers the clutch is pressed in to start the vehicle with my finger it causes the display to lose power, so it's not the pedal if that makes any sense. Also the check engine light has now come.
    Rocket350 and b3itz like this.
  2. Nov 14, 2020 at 6:57 AM
    Palanku
    Palanku Active Member
    Josue
    Puerto Rico
    2019 Tacoma Off-Road magnetic gray
    Gashole..TRD coin box..Ultimate turn light..TRD Pro grill..Black overlays emblems..Black Toyota exhaust..Hard metal tonneau cover..TRD pro shift knob..
    It's 2019 so the truck have warranty...take it to the dealer..
    Garyji likes this.
  3. Nov 14, 2020 at 7:52 AM
    resinball
    Yeah I have an appointment Monday.
  4. Nov 14, 2020 at 8:08 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Check the simple before you go. Battery connections and battery grounds. Been the #1 cause of electrical loads shutting down head unit.
    shakerhood likes this.
  5. Nov 14, 2020 at 11:48 AM
    resinball
    Battery connections are good and head unit is fine. It's the multi info display (MID) between the gauge clusters that goes out.
  6. Nov 14, 2020 at 2:52 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Did you get the battery tested?
  7. Nov 14, 2020 at 3:07 PM
    ShimStack
    Ben
    NC
    Oh my bad. Yea that's different.
  8. Nov 14, 2020 at 3:45 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Have you done any electrical mods?
  9. Nov 15, 2020 at 4:56 AM
    resinball
    Battery not tested. Electrical mods yes. Pro LED headlights, MESO total tail stage 1, dash cam, oem audio plus sound system, grill lights and bed lights. None done recently though.
  10. Nov 15, 2020 at 11:06 AM
    resinball
    Update: check engine light has turned off and issue has stopped. Scratching my head.
  11. Nov 25, 2020 at 12:16 PM
    resinball
    dealership found code P061512 Starter Relay Circuit
    Rocket350 likes this.
  12. Sep 28, 2022 at 5:52 PM
    Rocket350
    Rocket350 Member
    2019 TRD Sport MT
    Mine did the same exact thing yesterday. Check engine lamp went out today. Haven't done it since. Did you ever figure it out?
