Clutch Engagement
Discussion in '1st Gen. Tacomas (1995-2004)' started by larryshomework, Jun 8, 2010.
  1. Jun 8, 2010 at 3:04 PM
    larryshomework
    larryshomework [OP] Member
    Alabama
    01 4x4 5spd
    I have a "new to me" 2001 Tacoma 4x4, 2.7. The clutch doesn't engage (if that's the right word) until the pedal is almost completely on the floor. It doesn't slip and the pedal is firm but it let's out just barely off the floorboard.
    I did a quick check and the fluid seems to be at the right level. I had a Mazda B2000 before that had this problem due to low fluid.
    Is this normal? Adjustable?
    TIA
  2. Jun 8, 2010 at 4:11 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    It could be a pedal assembly adjustment issue ...
    The clutch pedal pushes a push rod to work the clutch. This push rod can be adjusted for play / travel.
    You can also adjust the pedal height (from floor to back of pedal).
