clutch fan help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hugh.a, Sep 19, 2021.
  1. Sep 19, 2021 at 8:37 AM
    hugh.a
    hugh.a [OP] New Member
    crosby texas
    07 tacoma 4.0 v6
  2. Sep 19, 2021 at 11:36 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t know the answer to that question.
    But I am going to say - Do not do it.
    You need to look at more than just the bolt pattern.
    The length is a big one, not to mention the temperature difference of the clutch.
    If the length is different at all you’re probably going to have belt alignment issues.
    You don’t want to sling a belt off on a 4.0. If it gets behind the crank pulley, you’re in for a big job replacing the oil seal.
    My advice is, watch your temp gauge.
    Save a bit of money, and do it right.
    gotoman1969 likes this.
  3. Sep 19, 2021 at 2:15 PM
    hugh.a
    crosby texas
    07 tacoma 4.0 v6
    dimensions all the same, i put it on and engine temp looks good much better, ill keep an eye on it, i think it will last till i can get the right one, i did some research and it looks like the green is for towing package first gen, may use more gas? thanks for your time
    TnShooter likes this.
