Clutch feels different after replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ass.floss, Jan 13, 2025.
  1. Jan 13, 2025 at 12:58 PM
    ass.floss
    ass.floss [OP] Member
    2022 TRD Off Road MT
    I got my clutch replaced and now it doesn’t feel the same. It feels “softer” than it did before. Is this normal? It was replaced with oem parts at the dealership.
  2. Jan 13, 2025 at 1:03 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Part of the transmission removal is disconnecting all the hydraulic fluid line stuff for the clutch release. Probably still working air out of the system due to that.
    I went with OEM parts for mine and now, it feels exactly like it did before…but only after a day or so of air working itself out of the clutch. Before then it was uber soft due to the air in the lines that is difficult to bleed. The system bleeds itself nicely over time.
  3. Jan 14, 2025 at 11:22 AM
    ass.floss
    That makes me feel better. It’s also reaching below freezing where I’m at, so I’m assuming that has something to do with how the fluid is moving through the system. Although it has been about 2 weeks since it was done.
  4. Jan 14, 2025 at 11:28 AM
    BLtheP
    Plano, TX
    That's a bit weirder then. I was assuming you just picked it up a day or so ago. Is the fluid in the reservoir at a normal level?
    The cold temps usually will make the pedal feel a lot stiffer, in my experience anyways.
  5. Jan 14, 2025 at 11:33 AM
    MGMDesertTaco
    Dirty brake fluid in the clutch hydraulic lines can make the pedal feel stiffer.
  6. Jan 14, 2025 at 12:18 PM
    ass.floss
    It’s way stiffer in the morning and then softens up as I drive, once it warms up it still feels softer than it did before I got it replaced. I also read that this “soft”feeling is pretty common with new clutches and should slowly go back to normal. I guess only time will tell. The car is running and shifting normal, I just don’t want to be putting any unnecessary strain on the clutch.
  7. Jan 14, 2025 at 12:21 PM
    ass.floss
    And the reservoir is full. Should I try bleeding the system?
  8. Jan 18, 2025 at 9:07 AM
    xaircav
    xaircav Well-Known Member
    Bill
    Wheat Ridge, CO
    '10 TRD Access Cab 6 speed manual
    TRD intake, skid plate, cat back exhaust and short throw shifter. Bilstein 5100 leveling front and 5100 shocks rear. 32” Falken WP AT4W tires on Gen 3 wheels.
    Do you mind sharing what the dealer charged you?
  9. Jan 18, 2025 at 1:40 PM
    ass.floss
    For a 2022 trd off road I paid a little under $3500. That’s from a dealership with oem parts in Arizona
  10. Jan 18, 2025 at 3:14 PM
    TheGrayNorthWest
    TheGrayNorthWest Well-Known Member
    I would definitely try bleeding it, just so you know for sure. Shops tend to be rushing when they put things back together, and the bleeding process was probably done in a hurry. There is often some air still in there that they didn't fully get out.
  11. Jan 19, 2025 at 1:00 PM
    DavidSmothers
    DavidSmothers Well-Known Member
    David
    Olive Branch MS
    2021 Tacoma TRD SPORT
    I bet bleeding it will firm it up.
    When I did the accumulator mod it firmed up a little as well.
  12. Jan 19, 2025 at 1:08 PM
    BLtheP
    Plano, TX
    I doubt bleeding at this point will do anything. The system is essentially self bleeding and often times, bleeding manually actually makes almost no difference. It usually just takes a couple days at most to work out any last bits of air introduced from a job.
  13. Jan 19, 2025 at 1:11 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    The freezing temps make a huge difference in clutch pedal feel on the Tacoma.
    eurowner likes this.
