Clutch feels "off" after getting new SS brake lines and flush.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacked Burton, Feb 17, 2022.
  1. Feb 17, 2022 at 3:41 PM
    Jacked Burton
    Jacked Burton [OP] Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    After getting new extended brake lines put on and a flush and fill of Motul dot 5.1 my clutch doesn't feel right.
    The first two or three inches of travel kinda just suck inward with 0 resistance then it firms up and the last few inches are engaging the clutch.
    Is it possible that having the brakes done could have cause this?
    I was under the impresssion they were two different systems.
    The mechanic specifically mentioned he didn't bleed the cluch because he didn't want to "open a can of worms".
    Thanks in advance.
  2. Feb 17, 2022 at 4:03 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It sounds like it got air in it, the clutch shares the same reservoir as the brakes on the trucks without the hydraulic brake booster so it's possible they got air in it when they did the brake fluid.
  3. Feb 17, 2022 at 4:04 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    System needs to be bled
    Jacked Burton[OP] likes this.
  4. Feb 17, 2022 at 4:09 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Best way to bleed clutch I have found is:
    Open bleeder
    Push clutch pedal down and hold
    Close bleeder
    Repeat a few times
    Then you can pump and hold, open bleeder a few times.
  5. Feb 17, 2022 at 4:40 PM
    Jacked Burton
    Thanks for the fast replies guys.
    Do yall think I'll need to add fluid afterwards or will the amount be negligible?
    If memory serves correct to add fluid I have to remove the shift boot and center console to get under the shifter.
  6. Feb 17, 2022 at 4:42 PM
    IvanhoeTaco
    Eastern NC
    Definitely keep an eye on the fluid level the whole time.
  7. Feb 17, 2022 at 4:44 PM
    Jacked Burton
    Stupid question but you're speaking about the brake fluid reservoir right. I didn't notice a separate one for the clutch.
    IvanhoeTaco[QUOTED] likes this.
  8. Feb 17, 2022 at 4:46 PM
    IvanhoeTaco
    Eastern NC
    How you liking the 35x11.5/17s? I love mine!
    Jacked Burton[OP] and AJKlug1 like this.
  9. Feb 17, 2022 at 4:47 PM
    IvanhoeTaco
    Eastern NC
    Correct
  10. Feb 17, 2022 at 5:02 PM
    Waasheem
    Waasheem
    2007 xrunner
    I had a hard time bleeding my clutch too. What worked for me was to put a piece of clear tubing tightly on the bleeder nipple, the other end in a container of brake fluid. Then pump the pedal, you'll see bubbles come out pushing the pedal down, pedal up the bubbles draw back up slightly towards the nipple, repeat until no bubbles are coming out. Then bleed like you normally would, the 2 man method.
  11. Feb 17, 2022 at 5:22 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    If you had a separate reservoir for the clutch fluid it would be pretty close to the brake fluid reservoir right along the driver side edge of the engine bay... I didn't realize that these trucks could be setup to have a shared brake/clutch fluid reservoir like this but it is apparently so. (Learned something new!) To answer your earlier question you definitely don't need to access the shifter area... it will all be done in the engine bay at the reservoir.
  12. Feb 17, 2022 at 5:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Im pretty sure there is a bleeder on the release cylinder ON the transmission.
    @Dm93 probably knows exactly where it is.
  13. Feb 17, 2022 at 5:30 PM
    azzwethinkweiz
    Tucson, AZ
    Yeah you're right, the slave cylinder has the bleeder and its mounted to the left side of the trans IIRC. I think I misinterpreted the guy earlier, I thought he was talking about removing the shifter boot and getting in there haha.
    TnShooter[QUOTED] likes this.
  14. Feb 17, 2022 at 6:37 PM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    Your mechanic is a willey one. Perhaps lazy is better.
    As folks are saying, reservoir is shared brakes/clutch. Just off the slave-cylinder, headed towards the rear, is a nipple for bleeding. The clutch moves a lot of fluid, so don't go overboard and run dry.
    Use a 3/8'' hose into a collection jug, pour some fluid into your jug for suction - and no air backfeed - place the hose onto the nipple, it'll be snug, and crack the nipple carefully till fluid begins to flow. Pump a couple times, to the floor and back, check rez, repeat till the firmness returns.
