Clutch fluid after 175k miles... gross
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, May 28, 2017.
  1. May 28, 2017 at 11:18 PM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Was way overdue. It was so easy idk why I put it off for so long. Can't even see through it holding up to the light.
    GQ7227 and jjsul like this.
  2. May 29, 2017 at 4:48 AM
    taco57
    taco57 Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    I do my clutch and brake fluid every two years. Never looked that bad, but clutch was always the dirtiest.
  3. May 29, 2017 at 6:22 PM
    Xjman1
    Xjman1 Well-Known Member
    JB
    2004 Tacoma TRD 4X4 X-CAB
    King coil overs, Rear shackle lift
    so could you feel any difference?
    GQ7227 likes this.
  4. May 29, 2017 at 9:48 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Not sure yet. I just took the truck around the block to make sure everything was okay. (Flushed brake fluid too). I couldn't tell a difference in that short drive.
    GQ7227 likes this.
  5. May 30, 2017 at 5:02 AM
    taco57
    Jeff
    Columbus Ohio
    No difference in feel, although it works out to be only about 30K between changes. Just feels better like a clean truck sort of thing. Piece of mind, just like the brake fluid.
    GQ7227 likes this.
  6. May 30, 2017 at 8:36 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Okay so yeah, definitely smoother shifting gears now or moving around the gear shifter with the clutch pushed in. Not as much of a notchy feel. seems to be smoother engaging the clutch too, but that's probably placebo. Who knows. Definitely needed to be done tho. I actually didn't have enough brake fluid left to clean it fully, but the lines are much clearer now. Guess I'll flush again in another 100k miles lol
    GQ7227 likes this.
  7. Nov 28, 2020 at 2:02 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Dude! I just hit 175k today finally after a long day out on the trails before winter hits or doesn't
    Clutch fluid has never been touched so it's probably gross too hahah
    Truck will likely need a new clutch next year depending on the current environment, especially if that release throwout bearing chatter gets any worse
    :spending:. Yikes!! With need of new tires probably as well next year :spending:
