Clutch Fluid Reservoir
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papabear050, May 12, 2009.
  1. May 12, 2009 at 5:13 PM
    papabear050
    papabear050 [OP] Well-Known Member
    11 dc 4x4 TRD OR Auto
    Can't find it.
    In all my manual tranny cars I had one. I traced around my engine and seems that the hose may be connected to the brake fluid reservoir
    Am I correct in assuming that our trucks don't have a seperate reservoir for the Clutch Fluid, instead it is shared/connected to the brake fluid?
  2. May 12, 2009 at 5:14 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Nope. They are always seperate. They are right next to each other on the driverside firewall.
  3. May 12, 2009 at 5:15 PM
    papabear050
    Imma go look... BRB
  4. May 12, 2009 at 5:18 PM
    DriverSound
    SoCal
    Too few to list.
    It's the small round one. The brake reservoir is connected to the booster.
  5. May 12, 2009 at 5:21 PM
    papabear050
    Negative, nothing there... If you messin with me...
    Kudos... you got me good.
  6. May 12, 2009 at 5:33 PM
    DriverSound
    SoCal
    Too few to list.
    We have the same truck, just different year. Clutch resorvoirs are always on the driverside firewall. Are you sure you don't have an auto? haha.
  7. May 12, 2009 at 5:39 PM
    papabear050
    Lol... you sure you have a clutch fluid reservoir????
    Have you seen this elusive creature with your own eyes, have you touched it, smelled it, or played with it?
    Seriously though, I don't have one. Another dam thing the Dealer ripped me on.... first it was my compass and temp, then they didn't give me my 7/4 pin converter, now THIS??
    ahahhahah.... Hey, you forgot to install my clutch fluid resorvoir asshat!!
  8. May 12, 2009 at 5:39 PM
    DriverSound
    SoCal
    Too few to list.
    This one is from a 4cyl but same location.
    The fluid on mine was kinda low at delivery so I had to fill it. That's why I know where it is. But then again it's always been on the same place on every manuals that I've had.
    Dannyblues likes this.
  9. May 12, 2009 at 5:49 PM
    wbhvacer
    wbhvacer Well-Known Member
    Cartersville Ga.
    Dodge Challenger Rt
    my 08 shared the brake fluid as clutch fluid
  10. May 12, 2009 at 5:50 PM
    papabear050
    Thanks Found It!!!
  11. May 12, 2009 at 5:52 PM
    papabear050
    Just messin around Driver Sound
    Thanks for the help. Seems the V6 and 4 bangers are different.
  12. May 12, 2009 at 5:52 PM
    DriverSound
    SoCal
    Too few to list.
    Damn, I've never heard of the brake and clutch using the same reservoir. I would definitely want those two seperate. I have to take a picture of mine when I get home. I'm driving the pathfinder today.
    btw, I have a V6!
  13. May 12, 2009 at 5:53 PM
    papabear050
    So I have a leak and lose my clutch, will I lose my brakes too? Interesting concept.
  14. May 12, 2009 at 5:54 PM
    papabear050
    Gotcha, let me know if you find it and if it looks anything like mine. :D
  15. May 12, 2009 at 6:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Doubtful- It's the reservoir. The pressure side is past the piston for either system. If the leak is past the master cylinder then you'll lose that system and most likely purge the reservoir, but not lose the other system as there should still be fluid for that system IN the system.
  16. May 12, 2009 at 6:17 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I had to scratch my head and read that a few times, then it made a lot of sense! good explanation there!
  17. May 12, 2009 at 6:22 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...
    If your brake system has a leak- you'll lose the brakes and the fluid out of the reservoir. Should have good clutch
    If your clutch system leaks- you'll lose the clutch and the fluid from the reservoir. Should have good brakes
    If them leak is before the master cylinder for either system- you'll lose the fluid in the reservoir, but should still have brakes and clutch (just no spare fluid)
    Little clearer DG???
  18. May 12, 2009 at 7:40 PM
    DanGer
    Haha i understood perfectly the first time, just took me a few passes
  19. May 12, 2009 at 11:29 PM
    DriverSound
    SoCal
    Too few to list.
    Here ya go.
  20. May 13, 2009 at 12:01 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Your right on except for that last statement.
    The problem here is.. If you have a leak anywhere in the system (clutch or brake) that is great enough to deplete the brake fluid allowing the reservoir to run dry, the brake system will fail to stop the vehicle and/or the slave cylinder will fail to operate due to a lack of line pressure.
    When the reservoir runs dry and you depress either the clutch pedal, or brake, air will enter the lines causing a significant loss of line pressure and failure.
    FWIW I have an '08 and my brake fluid reservoir doubles as a reservoir for the clutch like papabear's.
