Clutch Friction Point
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kram, Mar 17, 2010.
  1. Mar 17, 2010 at 10:55 PM
    kram
    kram [OP] Well-Known Member
    Squamish, British Columbia
    09 TRD Offroad Access Cab 6spd MGM
    URD Short Shifter TSB Leaf Pack, Bilstein 5100s front (1.75") and rear. 285/70/17 Duratrac on Rhino Sidewinders. Weathertech Digifit Floormats
    Would someone be able to describe to me how to adjust the friction point on the clutch so that it engages closer to the floor?
    I have another 6spd vehicle that engages much closer to the floor and everytime I get into it after getting used to the truck, I just about launch out of the driveway. I just want them to be more similar to ease the transition back and forth.
  2. Mar 18, 2010 at 12:00 AM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I believe the piston behind the clutch pedal is threaded and you can add freeplay by adjusting the nut.
  3. Mar 18, 2010 at 2:17 PM
    kram
    Thanks for the advice. I tried it and it worked to some extent. I was able to adjust the friction point much closer to the floor, however it also resulted in a very sloppy feel at the clutch, as it had to travel with little resistance for some way before it started pushing the cylinder in. I have returned it to its original position.
    If anyone has any tips on overcoming this play, whilst still keeping the friction point closer to the floor, I would love to hear it.
    Thanks
  4. Mar 18, 2010 at 2:33 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Not adjustable. You're only playing with the pedal adjustment there and it won't effect anything other than how far you're pushing the clutch master cylinder. Where your clutch engages is only adjustable if you have a cable actuator, which we do not have.
  5. Mar 18, 2010 at 3:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Concur with above^ What kind of "other" vehicle do you drive?? Cause my sports car with it's 5 spd feels completely different...but that's kinda the way it is. Sports car trans versus truck trans are different...so is seating posture.
    Just one of those things....at least imho.
  6. Mar 18, 2010 at 3:48 PM
    kram
    Acura TSX. It grabs almost as soon as it leaves the floor.
    Thanks to my URD short shift kit, the gearbox feels almost the same now, but I guess I'll have to get used to 2 clutches.
  7. Mar 24, 2010 at 3:00 PM
    Plannerman99
    So Cal
    Yeah, that sounds about like the result we got with my buddy's clutch pedal. It's been readjusted back to the stock position because the play was irritating.
