Clutch getting stuck
Discussion in '1st Gen. Tacomas (1995-2004)' started by warren_454, Sep 11, 2010.
  1. Sep 11, 2010 at 2:13 PM
    warren_454
    warren_454 [OP] Member
    Adam
    Ky
    02 TRD Tacoma
    TRD cat back, K&N cold air intake.
    I have a 2002 V6 4x4 with 127,000 mi, and the clutch is getting stuck all the way down and will not come up. I have to reach down with my hand or pull it up with my foot. It feels normal when I press it in but it just won't come up. It did this once three or four months ago and thought it was a fluke. Now it does it every time when starting in first and going to second and seems good from third and up.
  2. Sep 11, 2010 at 5:12 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Slave or master cylinder probably. Inspect the lines and look for leaks as well/check master level too. Bleed first then if not replace and bleed. There should be some more info on here if you search for it.
