Clutch groans when depressed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greenbean950, Nov 10, 2010.
  1. Nov 10, 2010 at 7:57 PM
    Greenbean950
    Greenbean950 [OP] Member
    01 Tacoma 4x4 Manual
    The clutch groans when I depress the pedal. It sounds like a heavily rusted door hinge and I can feel it through the pedal. It just started this two days ago.
  2. Nov 10, 2010 at 8:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Probably the bushings for the pedal. I believe there is a wright up around here somewhere to lube them.
  3. Nov 10, 2010 at 8:16 PM
    betardfoosier
    betardfoosier Well-Known Member
    Kansas
    2000 TRD SR5
    3" Skyjacker, 33x10.50 AT/TAs
    Yep mine does it too. Due for some grease.
  4. Nov 10, 2010 at 8:48 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  5. Nov 17, 2010 at 10:25 AM
    Greenbean950
    Thank you for the link to the bushing repair. Once I removed the clutch assembly, I found that the bushings that fit over the ends of the spring were also coming apart. They have become brittle and have allowed the spring to rub against the assembly hole in which it sits. Always something else.
  6. Nov 17, 2010 at 10:33 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I think everyone's pedal does this. It just needs a shot of white lithium grease. I lube mine every few months w/ a quick shot of grease. It tends to squeak more when it's warm/hot outside.
  7. Nov 17, 2010 at 10:45 AM
    Greenbean950
    How will that affect the edges of the hole where the spring attaches? It looks like it has already caused some wearing. I'd hate to have to replace the clutch assembly.
  8. Nov 17, 2010 at 10:46 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I groan when Im depressed too :(
  9. Nov 17, 2010 at 10:49 AM
    GA_TACO4x4
    GA_TACO4x4 Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    ^x2 :pout:
    :p
  10. Nov 17, 2010 at 5:44 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    ummmm throwout bearing?
