Clutch Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bhwang, Apr 10, 2020.
  1. Apr 10, 2020 at 7:41 PM
    Bhwang
    Bhwang [OP] Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    So I had the dreaded chip from my throw out bearing and decided I could drop the tranny and do that myself. Well success got it all back together....
    But when I went to start the truck the clutch pedal goes to the floor ?
    I pump it again and then it is rock hard barely any movement ...
    I use the clutch start cancel to start the truck and I try pushing in the clutch and hear a grinding, I have a look at the slave cylinder opening and I can see the clutch fork is going way to far and hitting into the flywheel.
    I never disconnected any lines or blocked them for the clutch. I just removed the slave cylinder and lines off the tranny when i dropped it.
    Am I to assume I need to bleed the clutch now ?
    Or am I missing something ?
    Thanks for any and all help !
  2. Apr 10, 2020 at 8:04 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    How is the clutch fork getting past the pressure plate and actually hitting the flywheel? That’s definitely isn’t right. Or do you mean it’s hitting the pressure plate?
    Jeffch likes this.
  3. Apr 10, 2020 at 8:15 PM
    Bhwang
    Josh
    Canada
    Tacoma
    Sorry I mean it is hitting the pressure plate
  4. Apr 10, 2020 at 8:19 PM
    gotoman1969
    Make sure the slave cylinder rod didn’t get pushed out of place. Then I’d bleed the clutch system and recheck.
  5. Apr 10, 2020 at 8:22 PM
    gotoman1969
    Also make sure one of the clutch forks didn’t slip off the throw out bearing.
  6. Apr 10, 2020 at 8:24 PM
    Bhwang
    Josh
    Canada
    Tacoma
    Ok i will have a look tomorrow, hope it is just a clutch bleed !
    Thanks
  7. Apr 10, 2020 at 8:27 PM
    gotoman1969
    Yep. Keep us posted. Good luck!
  8. Apr 10, 2020 at 8:29 PM
    gotoman1969
    Only other thing I can think of of is also make sure the fork didn’t slip off the little pivot that it sits on.
  9. Apr 10, 2020 at 8:37 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Sounds like it needs bleeding.
  10. May 12, 2020 at 8:42 PM
    Bhwang
    Josh
    Canada
    Tacoma
    So in the end, I had the wrong thow-out bearing, I guess there is two different types for the different trannies for our tacoma's. So lessons learned that I dropped the tranny twice and got the right one installed and it worked perfectly.
    Thanks for the help guys, no more chirping !!!!!!
    gotoman1969 likes this.
