Clutch help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rctmontana, Nov 26, 2023.
  1. Nov 26, 2023 at 11:08 AM
    Rctmontana
    Rctmontana [OP] Well-Known Member
    Bozeman, Montana
    2003 5 speed M/T 2.7 sr5 4x4
    While driving the other night I went to shift and couldn’t get into any other gears, it was stuck in neutral. Towed it home, replaced the master and slave cylinders. Checked for leaks, none present, bled the system and went a few reps further to confirm no bubbles. Pedal is still soft and won’t go into gear when running; it will go into gear when the truck is off. What am I missing? What else could be going on?
  2. Nov 26, 2023 at 11:49 AM
    Glamisman
    Glamisman Well-Known Member
    Did you bleed the master before you installed it or did you install it dry and hooked up the line?
  3. Nov 26, 2023 at 12:15 PM
    Rctmontana
    Bozeman, Montana
    I bench bled the master.
  4. Nov 26, 2023 at 12:30 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    Does slave appear to exhibit a normal amount of travel when the pedal is depressed? I would pull the boot at the shift fork and try to take a peak inside too.
  5. Nov 26, 2023 at 2:03 PM
    Glamisman
    Is there any free-play in the pushrod off of the clutch pedal?
  6. Nov 26, 2023 at 4:17 PM
    Rctmontana
    Bozeman, Montana
    It’s within the 0.2-0.6 range per the manual
    I’ll add, I’m not a mechanic I just enjoy fixing things myself. I’m not good at diagnosing vehicle issues yet.
  7. Nov 26, 2023 at 4:41 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    WITH NOTHING IN FRONT OF YOUR TRUCK, can you put it in first, push the clutch in, start the vehicle and let the clutch out and move normally, then shift gears as it should?
  8. Nov 27, 2023 at 10:06 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Then you said
    Did you bleed the slave too while it's in the truck? Seems like it took longer than needed last time I bled mine and was not functional right up to the last bleed. If it's "soft" meaning it will go down and come up but doesn't feel like it's disengaging the clutch, I'd go for still having air in the line.
    Did you have someone depress the clutch while you're under the truck, engine off, looking at the end of the clutch release fork? Is it moving when they press the pedal? If it's not moving, I say again still air in the line. If it's moving, adjust the clutch pushrod?
  9. Nov 27, 2023 at 11:11 AM
    Rctmontana
    Bozeman, Montana
    I didn’t bench bleed the slave, I did bleed the master. Yes, I had help with working the clutch as I lay under the truck with the bleed valve on the slave. In total I bled it for about an hour, saw no bubbles then went for another dozen or so reps on the clutch and confirmed no more bubbles coming out.
    the fork is moving I can watch the slave push on it when the bleed valve was closed, is it getting full travel though, idk. The pushrod for the master I have set to be within the 0.2-0.6 range specified in the manual and it seems to be engaging enough since fluid is definitely getting pushed through the system. Im leaning towards something with the clutch itself being bad, but I’m not great at diagnosing.
  10. Nov 27, 2023 at 11:11 AM
    Rctmontana
    Bozeman, Montana
    I haven’t tried that yet, I’m at work right now but I can check it later.
  11. Nov 27, 2023 at 4:37 PM
    Gen1andDone
    Failed release bearing?
  12. Dec 14, 2023 at 12:30 PM
    Rctmontana
    Bozeman, Montana
    Update: solved!
    finally ended up taking it to the shop. They were just as stumped as me, master and slave were fine, line was bled fine. But still sometimes pedal, sometimes not. They continued to bleed it thinking maybe there’s a stubborn air pocket somewhere in the line. While bleeding it the clutch fork broke. Said it was either bent or cracked (probably bent) and it wasn’t getting enough travel to engage the clutch, which makes sense because it looked fine from the outside but I couldn’t see inside the bell housing where the problem was. Mechanic said he’s never seen one break. I just feel vindicated at least that it’s not something I could’ve diagnosed on my own because I’m not qualified to drop my transmission or take it apart. Sucks that the labor will be expensive because the transmission has to come out to replace the fork but all in all just happy I didn’t mess something up. Thanks everyone for your help and suggestions.
    MadNachos, leid, Squirt and 1 other person like this.
  13. Dec 14, 2023 at 12:41 PM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    How old is the clutch? Might consider replacing that while it's out, since most of the labor will be the same
    ireymon likes this.
  14. Dec 14, 2023 at 3:59 PM
    Rctmontana
    Bozeman, Montana
    Asked them to check it and replace if needed, but it’s only got 50k on it so should be good for a while.
  15. Dec 14, 2023 at 4:00 PM
    1blink
    Storm Mtn, CO
    2000 3.4 manual SR5
    Agreed
  16. Dec 14, 2023 at 4:11 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have seen the pivot point of the fork break right through the fork.
    MadNachos likes this.
  17. Dec 15, 2023 at 7:54 AM
    Glamisman
    If I am understanding the issue… it sure sounds like the pilot bearing in the end of the crankshaft is stuck on the end of the input shaft of the transmission.
  18. Dec 15, 2023 at 2:26 PM
    Gen1andDone
    And that would cause the shift fork to bend or break?
  19. Dec 15, 2023 at 2:30 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    If the flywheel and pressure plate are flat I would consider tossing a new disc in it.
  20. Dec 15, 2023 at 2:31 PM
    MadNachos
    I have seen that on other makes. It happens.
