Clutch is depressed to the floor
Discussion in 'New Members' started by VAMonter, Apr 29, 2011.
  1. Apr 29, 2011 at 12:41 PM
    VAMonter
    VAMonter [OP] New Member
    VA
    95 Tacoma V6 Ext Cab 5spd
    I have a 1995 Tacoma V6 5spd with 255k miles on it. I tried to put it in gear last week and the clutch was completely depressed with no response. In addition to that I could not get it into gear. (I realize that if it would have gotten it into gear what would/could happen so no need to comment on that.) There had been a slow leak under the right center of the engine compartment but looked mostly like engine oil.
    I have very little experience with this type of repair but don't need the vehicle as a driver so time is not against me to learn what to do. Can anyone give me a hand as to what to look for in terms of where to start diagnosing the problem. ie, master cylinder, slave, linkage....Thanks for your help!
    -M
  2. Apr 29, 2011 at 12:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Bad slave cyclinder.
  3. Apr 29, 2011 at 12:49 PM
    VAMonter
    VA
    Thanks Chris. Any advice on how to repair?
  4. Apr 29, 2011 at 1:03 PM
    toytaco1
    toytaco1 Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    I had a similar problem on my 05 6 spd one day went to put it into second from first and didnt want to go into gear, it was my pressure plate after I removed it the plate was bent in. So I replaced it and I was good to go, could be the problem just a thought.
  5. Apr 29, 2011 at 1:06 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    you need a new clutch
  6. Apr 29, 2011 at 1:17 PM
    White Yodie
    White Yodie Member
    Texas
    08 PreRunner SR5 Old skewled
    Slave cyclinder---easy fix.
  7. Apr 29, 2011 at 1:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Here is the FSM. Scroll down to your year, and it should be in there. :)
  8. Apr 29, 2011 at 1:40 PM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    bad slave would mean there is no pressure on the pedal... do you feel pressure at all? or does it just sink to the floor pretty easy? I wouldn't jump on the slave cylinder bandwagon just yet.... does the pedal come up on it's own?
  9. Apr 29, 2011 at 1:41 PM
    Brunes
    Brunes abides.
    Rotorhead
    While I don't disagree with your assessment based on milage....Clutch wear would not make you bottom out the pedal....Slave cylinder is a better place to start.
  10. Apr 29, 2011 at 1:47 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    is the slave cylinder the same thing on a master cylinder? cause you could have bent the little piston in the mastercylinder
  11. Apr 29, 2011 at 1:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good point!
  12. Apr 29, 2011 at 2:04 PM
    VAMonter
    VA
    Thanks all for the comments and suggestions. It got me out to and start looking around...what I found was that when I pulled the clutch up from the floor it started working just fine. That raises a bit of concern about what problem caused that. If someone happens to have any experience with this, let me know.
    Thanks again
