clutch issue!
Discussion in '1st Gen. Tacomas (1995-2004)' started by aferalhamster, Jun 26, 2011.
  1. Jun 26, 2011 at 5:06 PM
    aferalhamster
    aferalhamster [OP] Well-Known Member
    Luis
    Sanford
    2002 SR5 v6 PreRunner Stock
    CB
    Here's the deal, my clutch pedal is extremely soft all of a sudden. It started 2 days ago. I checked the reservoir and it was a little low so I refilled it. It got better. As of this morning I will not drive it because its to the point where it wont disengage the drive anymore. I push the clutch all the way in and it is stiff going in but if I keep it in more than a second it looses tension and the drive engages. I can have the pedal all the way to the ground and the truck will drive away. I feel like it might be compressing and then the fluid is slipping by somehow. I dont know if it would be the master cylinder or the slave cylinder. Please help. I have a 250 mile drive in a two weeks and I need to be able to fix it by then. I dont want to put a lot of money into this either because I will be getting a 2002 Prerunner in a month and trading the 99.
    Any help will be welcome.
  2. Jun 26, 2011 at 5:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If it starts to build pressure & then looses it, I'd say its the clutch master/slave cylinder
  3. Jun 26, 2011 at 6:03 PM
    aferalhamster
    Luis
    Sanford
    CB
    I figured that, but which one. Or should I just replace both?
  4. Jun 26, 2011 at 7:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    you should always do both if its not too much $$ I reckon, I know if I did just one, bigger than shit I'd be back under it replacing the other....;)
  5. Jun 26, 2011 at 8:12 PM
    aferalhamster
    Luis
    Sanford
    CB
    thank you
  6. Jun 26, 2011 at 9:02 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    It's nice to know I'm not only one to whom this happens... :rolleyes:
    OP, if you haven't already done so, you should try bleeding the clutch (similar to bleeding the brakes), to ensure you don't have any air in the lines. 4WD is probably right, but bleeding the lines won't cost you more than a few ounces of brake fluid and few minutes of your time.
  7. Jun 27, 2011 at 12:14 PM
    aferalhamster
    Luis
    Sanford
    CB
    good to know. How do I accomplish this?
  8. Jun 27, 2011 at 12:46 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    I had this issue with mine at one time. I would stop at a stoplight with the truck in gear with the clutch engaged and all of a sudden the truck would start rolling. I drove like this for about two weeks before I found time to work on it. I would just have to tell myself to pull the truck in neutral at any stop I would make, when I could go again, I would push the clutch ina nd put it in gear quickly and take off. lol......... it sucked and was very very dangerous in terms of hitting someone in the rear end while I was stopped. My pedal would sometimes not come back up and I literally had to pull it up with my foot. I ended up changing out the master cylinder and it fixed the issue. But check your slave cylinder first to make sure you aren't leaking there. Its definately either your master cylinder bleeding by or a faulty slave cylinder.
  9. Jun 27, 2011 at 12:48 PM
    offroadTRD
    I forgot that you mentioned that you wanted to know which part might be defective....... I'm going with your master cylinder since that is what was faulty on my truck. Hope this helps.
  10. Mar 12, 2013 at 4:05 PM
    sonnytris
    sonnytris Member
    san antonio tx
    2003 2wd
    I have thw same problem with my 04 taco 5 speed? Where is the master item located ? is it under the hood nexct to brake fluid revsovier? . If i replace it that should stop my problem?
    Thanks
    sonny
  11. Mar 12, 2013 at 6:06 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    yes, it is next to th e brake MC. see if that or your slave cylinder is leaking. replace whichever is leaking.
  12. Mar 12, 2013 at 6:09 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    WeatherTechs, Console Vault, OEM Bed Mat, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, Exterior Cargo Net, OEM Toyota Cargo Divider, Cobra CDR 840 Dash Cam, Sliding Rear Window Security Bar, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Full Debadge except TRD OEM Red Tailgate Badge, Undercover SE Tonneau
    Yep agreed - Master / Slave Cylinder.
  13. Mar 12, 2013 at 9:57 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    The Master cylinder goes bad more often on these trucks.
    I would try and bleed the system first, and if that doens't help, go ahead and replace both the slave and master. It wont hurt to replace both, and more than likely both are getting pretty old anyways.
    Marlin Crawler sells some quality Japanese units on their site for a good price. Just avoid autozone and advanced auto units because they dont last long. I am on my second autozone master cyl in a year. Will be getting a marlin crawler unit after this one takes a dump.
    You can also rebuild your slave cylinder, outlined in the link in my signature.
