clutch issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by supadave888, Mar 28, 2010.
  1. Mar 28, 2010 at 7:39 PM
    supadave888
    supadave888 [OP] Well-Known Member
    morgan city La
    4x4 trd sr5
    ive done some searching but havent seen my answer.. i have a 2005 manual tranny and its lightly grinding from 4th to 5th gear only.. anyone know the reason and how to fix? a few ppl tell me new clutch but just wanna get you guys opinions..
  2. Mar 28, 2010 at 7:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You probably need to change your tranny fluid. I recommend redline MT-90.
    Its definitely not a worn clutch.
  3. Mar 28, 2010 at 7:48 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah..If the person who is telling you to get a new clutch- If they are a friend- Do not invite them to Christmas dinner any more. If it's a business- do not go back there.
    It could be a syncro going or a damaged gear...but I think SteveO is right....Change the trans fluid with some good synth and see what happens.
  4. Mar 29, 2010 at 11:39 AM
    supadave888
    morgan city La
    4x4 trd sr5
    thanks guys ill give that a shot.. what do you guys recomend? what kinda price? where can i get it at?
  5. Mar 29, 2010 at 11:41 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    this
    Im not sure how much the second gen takes though. My first gen 5 speed takes a little under 3 quarts.
  6. May 4, 2010 at 7:16 PM
    derrenwd
    derrenwd Member
    ontario canada
    2005 trd offroad 6 speed
    k&n intake, banks cat back, 3 inch block lift with rear aal, MagnaFlow "Direct fit headers and cats" URD short throw shifter kit
    anyone know about a syncro change out
  7. May 5, 2010 at 6:17 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I've rebuilt several manual transmissions, but not one from a Tacoma; what do you want to know? Obviously the trans needs to come out, disassemble, and the main shaft assy needs to be completely disassembled; typically a hyd press is required and some special tools like bearing puller plates and some very HD snap ring pliers (not like what you're used to). Any local 4WD or trans shop should be able to do it for you as the insides of a manual transmission are basically the same as far as what a person would need to know to do it- you shouldn't need to go to the dealer but might want to provide a service manual if they don't have one. If you can pull the trans you will probably save half the total labor.
  8. May 5, 2010 at 6:24 AM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    MT 90 made my tranny worse. I think i got a trans with a little looser gears...so when i put a thinner/syn gear oil in...it made the shifting worse....the stock dealer gear oil seems to work the best
  9. May 5, 2010 at 6:34 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    MT-90 is not thinner than any other 90 weight oil, it just holds its viscosity to lower temps and lubricates better. It did help my tranny so I don't know.
  10. May 5, 2010 at 6:22 PM
    supadave888
    morgan city La
    4x4 trd sr5
    5 gear has a lil glitch before it goes into that gear. brought it to a tranny shop and the guy said its deffinately a sycronizer.. they gotta send em off to get them rebuilt. i just go around that gear for now..
  11. May 5, 2010 at 8:19 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    How often does this fluid need to be changed? Where is the drain hole, and refill hole, and is there a filter? I have never messed with manual transmission fluids. Only autos. Thanks guys.
