Clutch issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter11199, Jan 19, 2011.
  1. Jan 19, 2011 at 6:52 PM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
  2. Jan 19, 2011 at 6:53 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Are you loosing fluid?
  3. Jan 19, 2011 at 7:05 PM
    bowhunter11199
  4. Jan 19, 2011 at 7:08 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    weird. And you're sure the grabbing still happens when everything is up to operating temp? I know mine can have a slight grind when going into 2nd, especially when cold.
  5. Jan 19, 2011 at 7:11 PM
    bowhunter11199
  6. Jan 19, 2011 at 7:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah if its only 2nd gear its probably not the clutch. Maybe you could try changing the tranny fluid to synthetic (redline MT-90 or Amsoil).
  7. Jan 19, 2011 at 8:05 PM
    bowhunter11199
  8. Jan 19, 2011 at 8:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    The only problem with that oil is that its GL-5 which is not so good for the brass syncros in the tranny and can cause them to corrode. The redline or amsoil will be GL-4 which is safe to use with brass.
    Oh and the axles and transfer case are fine for at least 60k with that oil.
  9. Jan 20, 2011 at 5:47 PM
    bowhunter11199
  10. Feb 2, 2011 at 7:50 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Maybe the "Slave Cylinder" When you say bitting do you mean it hard to shift out of a certin gear? Cause I just bought a 1996 2.4 4cyl tacoma. and it does the same thing. Does any one know if all clutch fluid is the same cause my grandpa said toyota might use a certain kind and if I don't use the right one I can contaminat the whole "system".
  11. Feb 2, 2011 at 8:25 PM
    bowhunter11199
