Clutch kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ODICA, Sep 28, 2011.
  1. Sep 28, 2011 at 12:23 PM
    ODICA
    ODICA [OP] 06 TACOMA 4X4
    Earl
    Beaumont, CA
    06 4X4 SR5
    I dropped my truck off at the shop this morning so they could install my new throw out bearing from PDM and the stage III clutch kit from URD. Im crossing my fingers that there wont be anything wrong with the transmission when they open it. My truck is a 06 and it has 82k miles right now and my TO bearing just started chirping at 80k miles. What possible scenario that could be wrong with the trans?
  2. Sep 28, 2011 at 12:37 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    not sure, but sub'd to see what you think about that stage III....
  3. Sep 28, 2011 at 12:40 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, GrillCraft Grill, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley.
    X2
  4. Sep 28, 2011 at 12:45 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    most likely you won't see any problem...you're truck is still new man...these things can take a beating
  5. Sep 28, 2011 at 12:53 PM
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    What is the difference between the factory clutch and the URD stage 3? My 06 has DC/OR has the towing pkg and I pull a 4200# + travel trailer regularly. Should I upgrade? Would I feel the difference? How so?
  6. Sep 28, 2011 at 1:11 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Stage III is really grippy. Like, really grippy. I've heard people describe their clutch as an on/off switch after the upgrade as it grabs so hard.
  7. Sep 28, 2011 at 1:26 PM
    ODICA
    Earl
    Beaumont, CA
    06 4X4 SR5
    I just could not stand the chirping on my TO bearing.
  8. Sep 28, 2011 at 1:28 PM
    ODICA
    Earl
    Beaumont, CA
    06 4X4 SR5
    Cant answer your questions yet. But check out URD clutch kits or CCI competition clutch stage IV kit if you tow a lot.
  9. Nov 26, 2011 at 2:02 PM
    billmo715
    billmo715 Member
    Bill
    Southern California
    06 PreRunner TRD
    Hello, I too have a 2006 manual tacoma with 75K miles, and I am experiencing the chirping/whining noise. I was wondering where/ how you purchased the PDM throw out bearing kit, because that seems to be the best option. Also, has the PDM successfully eliminated the noise so far? In regards to the stage III clutch kit from URD: did you get this due to the chirping noise or was it just to upgrade the clutch?
