Clutch knocking ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scyot89, Oct 17, 2011.
  1. Oct 17, 2011 at 10:22 PM
    scyot89
    scyot89 [OP] Active Member
    TJ
    South Carolina
    2002 Tacoma 3.4L 4X4 5spd
    Stock
    I have a 2002 Tacoma 5 spd 4x4. I have noticed when i crank the truck up for the first time in a few hours or especially in the mornings when I let out on the clutch it feels like somethin is grabbing and its hard to get the truck to move. Also when I push the clutch back in something will make a loud knocking noise. anybody know what the problem is. ? by the way its not my ebrake.
  2. Oct 17, 2011 at 10:24 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    how many miles?
  3. Oct 18, 2011 at 6:10 AM
    scyot89
    TJ
    South Carolina
    Stock
    156,000
  4. Oct 18, 2011 at 6:25 AM
    radcat692000
    radcat692000 Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    have you checked to see if your clutch slave or master cylinder is loosing fluid... ??? sounds like its doing that since you said its doing it after it sits awhile
  5. Oct 18, 2011 at 6:27 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    if your not loosing fluid, it maybe your pilot bearing..
  6. Oct 18, 2011 at 6:36 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Pilot bearing would make noise all the time when it starts to go. It supports the input shaft of the transmission and is pressed into the flywheel. You might have been thinking throwout bearing.
    I would suspect a clutch fork or a throwout bearing problem. A close inspection while someone operates the clutch might reveal the problem.
