Clutch makes noise when pressed in.
Discussion in 'Technical Chat' started by pl87pll, Apr 6, 2012.
  1. Apr 6, 2012 at 12:44 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    06 Tacoma 4wd Access Cab
    K&N Cold air intake,Dual exhaust Magna Flo.
    Hi, I have a 2006 tacoma 4x4 6 speed and here lately when I press the clutch pedal in I hear a squeeshy noise happen, it just sounds like a sponge with water in it and makes a squeeking noise and I was just wondering if this means something bad and should I get it checked out.. Thanks in advance.
  2. Apr 6, 2012 at 12:55 PM
    DrewH
    DrewH Well-Known Member
    If you just mean the pedal squeaks when you push it in then you can fix it.
  3. Apr 6, 2012 at 1:15 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    Its not the pedal making the noise, its coming from somewhere else and if it is throwout bearing issue do I need to get it fixed and if so how much will that be?
  4. Apr 7, 2012 at 1:54 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    Thanks for the info PSU Taco85 and also I was looking at the pics of your truck and that looks bad ass man, nice job... One more thing since it looks like you know what your doing... I got a K&N cold air intake and dual exhaust magna flow in hopes to get better gas mileage and horsepower which I did with the horsepower but my gas mileage has actually gotten worse since I put those on and I was just wondering if there is some kind of reset I need to do for the truck to recognize them and actually get better gas mileage.
