Clutch master cyl push rod is bent (solved)
Discussion in '1st Gen. Tacomas (1995-2004)' started by NC Gazzer, May 11, 2023.
  1. May 11, 2023 at 9:12 AM
    NC Gazzer
    NC Gazzer [OP] Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Yesterday my clutch pedal suddenly became hard than normal to push in. With a bit of leg effort, I could disengage the clutch and shift gears though. This morning I took a good look at the pedal assembly and found the push rod to be bent just past the lock nut at perhaps a 15 deg angle.
    I'm going to try to bend it back straight, but I'm not optimistic about complete success. I reckon I'll probably ending up replacing the master.
    My question is: How in the heck can this rod bend? The pedal assembly seems to be in good shape after my quick look. The bigger question is that if I replace the master, should I expect the push rod on the new one to be in jeopardy of bending.
    Truck is a 96 4wd with 2.7. 116,000 miles.
    Thanks
  2. May 11, 2023 at 9:42 AM
    NC Gazzer
    Durham, NC
    To respond to my own question, perhaps this older post is relevant
  3. May 11, 2023 at 9:57 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    There is a reason it bent you need to figure out just why!
    Clutch bracket cracked or the firewall cracked. I have seen both these things.
    Possible the hardware holding the clutch master cylinder came loose allowing things to flex.
    Clutch Master cylinder casting broke at the ears allowing it to flex.
    Most aftermarket Master Cylinders the hydraulics fail not the hardware .
    Good luck!
    NC Gazzer[QUOTED][OP] likes this.
  4. May 11, 2023 at 10:48 AM
    NC Gazzer
    Durham, NC
    Well, it turned out that the rod was not bent. The bushing at the clevis had failed allowing the rod to 'jackknife'. I have a new Aisin cylinder ordered.
    Bivouac likes this.
