Clutch Master Cylinder Availability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaWannabe84, Feb 5, 2023.
  1. Feb 5, 2023 at 8:26 AM
    TacomaWannabe84
    TacomaWannabe84 [OP] New Member
    2008 2.7 4x4 5 speed
    Will the master cylinder from a 2012-2015 p/n 3142004020 fit on my 2008 2.7L? I've had a master cylinder on order from my Toyota dealer for many months and there is no availability. The p/n 3142004011 listed for my '08 truck is no longer available and says replaced by the one above. Can anyone tell me if they are compatible? Thanks
  2. Feb 5, 2023 at 12:44 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    31420-04020 is the same cylinder, but has a different clevis shape. It likely won’t interface correctly with your pedal unless your truck had a TSB performed on it already.
    You have several options, which I will list, along with my recommendations.
    1. Order 31420-04020 and reuse your original clevis (assuming you don’t have the TSB update).
    2. Order 31420-60032, 31434-60010, 31311-04021, and 90389-06055 to update to the newer aluminum master cylinder and pedal.
    3. Order 31301-35270, 90389-06055, 90541-06036, 31420-35070, 31454-30030, 31434-60010, 31404-35013, 90240-T0002, 90386-08033, 90206-08001, and 90468-15006 to upgrade to an all-metal design from the FJ Cruiser/Land Cruiser.
    Details: https://www.tacomaworld.com/threads...-tsb-t-sb-0112-19.635065/page-5#post-21891255
    Jeff
    TacomaWannabe84[OP] likes this.
  3. Feb 5, 2023 at 9:14 PM
    TacoTuesday1
    SD CA
    I would check RockAuto and order what they say fits unless you upgrade. Likely 3x cheaper
