Clutch Masters v. Tilton T.O.B.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Pastor, Mar 10, 2022.
  1. Mar 10, 2022 at 4:29 PM
    Taco Pastor
    Taco Pastor [OP] Well-Known Member
    Brian
    2009 Tacoma V6 access cab 6spd Barcelona rec
    I just read that the clutch masters seal leaks and I checked online and another guy(he has mustang) had the same problem.
    I have a 2009 Tacoma V6 6spd. What parts do I need for Tilton Hydraulic T.O.B.? I can order from Bowler here in IL, but I talked with them because they deal with Tilton, but they had no idea the combination as there is not a specific bearing, but only parts from another tag I remember here that I lost after this computer crashed. I just got it back two days ago.
    I am doing a CLUTCH AND HEAVY FLYWHEEL FROM LCE June 1st. A friend from PA is coming to IL to help me. Now that's a friend.
    Key-Rei likes this.
  2. Mar 10, 2022 at 4:32 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Was probably part of @BillDaCat8 's RC62 swap and shenanigans thread, that should help you find it.
    FWIW Bill's setup is probably the only hydro bearing I would even consider, I used URD's stainless quill sleeve kit and it seems to be doing alright.
    Am seriously considering a RC62 trans swap though.
    TodayWasTHeDaY likes this.
  3. Mar 10, 2022 at 4:36 PM
    Taco Pastor
    Brian
    Were can I find a used transmission? How do you make it fit. Is it glove?
  4. Mar 10, 2022 at 4:37 PM
    Key-Rei
    Key
    Florida
    BillDaCat8 likes this.
  5. Mar 10, 2022 at 4:37 PM
    Taco Pastor
    Brian
    Thanks!
    Key-Rei likes this.
  6. Mar 10, 2022 at 4:42 PM
    Taco Pastor
    Brian
  7. Mar 10, 2022 at 9:32 PM
    TacoTuesday1
    SD CA
    For used trans look through eBay and carpart com for junkyards
    unfortunately carpart com is not the most accurate in terms of actually seeing for yourself local inventory at junkyards since they don’t always list/post the cars they have
  8. Mar 11, 2022 at 1:58 PM
    Taco Pastor
    Brian
    Thanks for ya help sir!:thumbsup:
