Clutch Noise Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cvd2312, Dec 19, 2011.
  1. Dec 19, 2011 at 12:06 PM
    Cvd2312
    Cvd2312 [OP] Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Hoping some of you guys can help me with the noise I'm hearing from my clutch...
    After searching on here, I've found that the throw out bearing makes a whiny/squeeling noise when the clutch is NOT engaged. Well, my clutch is making noise only when the clutch pedal is pushed in/engaged. It is a winding/whiny noise, similar to what I've heard described as the throw out bearing. But at idle there is no noise, like I said only when I push in the clutch, and it does not happen all the time, it may do it one day and not the next.
    Does this still sound like a throw out bearing? Thanks in advance for the help!
  2. Dec 19, 2011 at 12:09 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Bad pilot bearing is my guess.
    Plan on replacing everything sometime soon before it really comes apart.
